20 Most Recent Umax PowerLook III Prepress Flatbed Scanner Questions & Answers
Need a motor for powerlook iii
Support That link is to the oem page.
12/22/2017 12:40:26 AM • Umax PowerLook... • Answered on Dec 22, 2017
Umax powerlook III scanner not working with latest mac system sof
Your OS is not compatible. Period. Either go back to what worked for you or get a new scanner that will work in new environment.
6/23/2017 3:43:17 PM • Umax PowerLook... • Answered on Jun 23, 2017
Umax powerlook III
I had that problem...it sounds like a SCSI bus problem...If you have a Mac...you can get a Ratoc SCSI to firewire converter...it solved my problems..Take Care, Carole
4/8/2009 8:24:24 PM • Umax PowerLook... • Answered on Apr 08, 2009
Trying to connect Umax PL 2100XL (SCSI) to G4 - scanner not found
I just told someone else this solution...KILL the SCSI junk...I had nothing but trouble with it with my Mac....I got a Ratoc Firewire to UltraSCSI Converter...to solve the regular SCSI to ultra SCSI problem...I also bought an adapter....It works great...no need for a SCSI card...or a driver...you just plug directly into your firewire port! If anyone can help me with my TA adapter startup problem...I'll be thrilled! Carole
4/8/2009 8:21:46 PM • Umax PowerLook... • Answered on Apr 08, 2009
Won't complete initialization/calibration
Hi...I  have a PowerLook III, and that sounds like the super frustrating problem I used to have...first of all, don't worry about it not being used for awhile...I didn't use mine for 10 years and now it's great...except my Trans adapter problem. Anyway...I am running Mac OSX.4.11...I got a Ratoc SCSI to Firewire adapter from the Lasersoft people..they make the Silverfast scanninng software...and my scanner works great..no more creepy SCSI bus and driver and card issues...I highly recommed one...I hope this helps! Carole
4/8/2009 8:16:57 PM • Umax PowerLook... • Answered on Apr 08, 2009
How to clean underside of glass of a Umax
Normally you should not have to do that. If you do you have to take the glass off.
8/28/2013 2:53:56 AM • Umax PowerLook... • Answered on Aug 28, 2013
2answers
Umax mirage II not working, not recognized on xp
Hi. I have a Mirage II A3 scanner that was working fine till I save it in a closet a few years ago. Now I need it again, but I don´t have the PC I used to have with ISA port... I finally found a brand new PCI card I had in another Umax scanner, so I connected it to the PCI slot in my actual PC. And I cannot connect the scanner... I installed the software correctly, but in Test mode, it gives me a Link failure. Besides, the scanner does its setup when powered on, the lamp goes from right to left, stays there a few seconds and return to its original position. But the UTA and READY lamps keep blinking... I found this page:https://ask.adaptec.com/app/answers/detail/a_id/1869/~/scanner-test-link-failures-with-umax-scanner, that explains this can be fixed upgrading the software, but the link does no longer exist... Could you please send me the software I need to connect it..? It´s really important I can do this. I have a huge job to do but it doesn´t work... I´l be waiting for your answer. THANKS!!
8/9/2019 2:48:53 AM • Umax Office... • Answered on Aug 09, 2019
UMAX PowerLook 2100xl scanner termination
Only one termination should be powered in a SCSI chain. Generally, it should be the last device. It's been a long time since I've worked with SCSI, but I recall that scanners may be picky about where in a chain of multiple devices they are located; electrical noise on the SCSI data lines causes problems with the scanner electronics. I don't recall whether best results are found from locating it as the first device in line from the computer or the last device.
8/25/2018 11:37:24 PM • Umax Office... • Answered on Aug 25, 2018
3answers
I need umax Astra 5800 Scanner Driver and Software
i lost my scanner dirver
4/3/2018 2:57:13 AM • Umax Office... • Answered on Apr 03, 2018
Umax PowerLook III Prepress Flatbed Scanner Logo
Popular Tags
6 questions posted
Top Umax Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
PowerLook Umax
  • PowerLook Umax
Most Popular Question
need motor poerlook iii
  • Office Equipment & Supplies
