20 Most Recent Umax Astra 3400 Flatbed Scanner Questions & Answers
It will not turn on. What do I have to do? I bought this some time ago but it has never been used.
I presume this is a scanner that uses a USB connection to your computer. You will find that it does just about nothing until you have it connected both to power and to a computer's USB port. You must also install the appropriate drivers and software. Only then will your computer activate the scanner when you actually try to scan something. The only thing that will activate with only the power cord connected is the scanning lamp inside it so lift the lid and connect the power cord. If the lamp comes on but nothing else, it's just doing what it's supposed to do.
3/5/2015 10:10:55 AM • Umax Astra 3400... • Answered on Mar 05, 2015
I want to download driver for window 8
You will probably have to try and use the existing XP driver. When installing the driver software in windows 8, make sure you install it in "compatibility mode" and tick "Windows XP R2".
6/8/2014 1:11:13 PM • Umax Astra 3400... • Answered on Jun 08, 2014
Asking for adapter cable for scanner umax astra 3400
Should be a standard USB device cable. Any half decent home electronics store sells them. The same cable is used to connect most USB printers.
6/8/2014 1:08:26 PM • Umax Astra 3400... • Answered on Jun 08, 2014
While driver installation system needs windows xp professional CD
You need to get a new scanner. Microsoft is not going to support Windows XP anymore period. It is so outdated...please.
4/15/2014 3:42:18 PM • Umax Astra 3400... • Answered on Apr 15, 2014
0answers
3answers
Drivers/software for Umax Astra 3400 scanner
http://www.scanner-drivers.com/drivers/59/59878.htm
the link above will take you to the drivers you require, it says windows me but also in the comments it says for XP as well.
I hope this works for you.
6/28/2013 12:19:45 PM • Umax Astra 3400... • Answered on Jun 28, 2013
4answers
Astra 3400 Driver for win vista
Simply do this.
Start/Programs/Accessories/System Tools/Compatibility Wizard
Set the machine for XP or Win 98
3/1/2013 5:55:18 AM • Umax Astra 3400... • Answered on Mar 01, 2013
2answers
I want 5600 umax astra scanner driver
Go here for the driver for the umax 5600 astra scanner:
http://www.opendrivers.com/freedownload/233307/umax-scanner-astra-5600-5650-driver-windows-98se-me-2000-xp-download.html
Go down the page and put the code you see into the box. It looks like this:
Press Download.
Fixya!
Chris (ziraffa)
ps Remember to rate this solution as Fixya!
12/5/2012 12:55:44 PM • Umax Astra 3400... • Answered on Dec 05, 2012
Lines on scanned page
Could be the scanner is hesitating as the carriage moves - bad gears perhaps. Hhave you thoroughly cleaned the glass and wiped it dry? Is the scanner level andand fully unlocked? I would try these quick fixes first. If they don't work, scanners are cheap nowadays.
10/25/2012 10:48:00 AM • Umax Astra 3400... • Answered on Oct 25, 2012
6answers
DRIVER FOR UMAX ASTRA 4100 FOR xP OS
i want to install UMAX ASTRA 4100 Scanner with my computer having operating system windows XP. Please send me driver for installation of UMAX ASTRA 4100 Scanner
V M MECWAN
8/27/2012 3:44:22 PM • Umax Astra 3400... • Answered on Aug 27, 2012
4answers
UMAX Scanner
6/12/2012 1:20:48 PM • Umax Astra 3400... • Answered on Jun 12, 2012
Driver for windows 7 64 bits
i need umax astara 3400 drive for windows 7
1/8/2012 3:17:26 AM • Umax Astra 3400... • Answered on Jan 08, 2012
Please help me i need
Your device is not fit to run under Windows 7 .
Try installing a virtual version of XP on your system : http://download.cnet.com/VMware-Player/3000-2094_4-10470784.html
or purchase a W7 compatible replacement device ( starting from 100 $ ) .
Best regards ,
fanaudi .
9/13/2011 7:15:55 AM • Umax Astra 3400... • Answered on Sep 13, 2011
Umax 3400 windows7 no driver
Try running the software in compatibility mode on Win7. To do this:
1. Right click the software and go to Properties
2. Look for the Compatibility Tab and select it
3. Check the box marked Run this program in compatibility mode for XP Service Pack 3
4. Check the box that says Run As Administrator
5. Click OK and see if that works
Since there's not a compatible driver for Win7, you might not be able to do much about it until they release a driver for it.
8/26/2011 1:12:29 AM • Umax Astra 3400... • Answered on Aug 26, 2011
Need driver for windows 7
Sorry, the manufacturer has not released a driver for either Vista or Windows 7. You can try other Umax Astra drivers and see if one of them will work.
5/1/2011 8:41:10 PM • Umax Astra 3400... • Answered on May 01, 2011
Umax Astra 3400 Flatbed Scanner Logo
150 questions posted
Top Umax Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Astra Umax
  • Astra Umax
Most Popular Question
lines scanned page
  • Office Equipment & Supplies
