20 Most Recent
Samsung UN55D7000 55 in. 3D LCD TV Questions & Answers
Samsung LED TV has dark area on top
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
11/20/2015 2:36:18 AM •
Samsung...
Answered
on Nov 20, 2015
HOW DO WE GET IT TO SWITCH ON
The capacitors on the power supply need to be replaced. When you take apart the TV, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video on how to replace capacitors.
11/25/2014 9:27:36 PM •
Samsung...
Answered
on Nov 25, 2014
Hdmi are not being found
It's either the cable or the source. Try a different cable first, then try and plug different sources (DVD, blu ray, xbox , etc.) Also check all inputs and make sure it's not just the one input.
4/10/2014 10:34:40 PM •
Samsung...
Answered
on Apr 10, 2014
