20 Most Recent
Umax PowerLook 2100XL Flatbed Scanner Questions & Answers
Power & ReadyLight come on scanner. Scanner
Hello
It sounds to me that you have a power problem! Make sure your scanners power adaptor is working properly! And that the one you are using really is meant for your scanner!
Check Volts and Amps on it! It´s not normal that the lights on it´s flickers!
It also Could be a SCSI termination issue. Try changing the SCSI address number on the scanner to a different one and make sure the chain is terminated properly. If there are multiple SCSI devices in the chain, disconnect all the others until you are sure the scanner is working then slowly add the other devices to the chain making sure everything works as each device is added. SCSI voodoo!
I have an UMAX Powerlook
there are some Firewire to SCSI and USB to SCSI adapters that should work- check www.hamrick.com.
Ed Hamrick has written Vuescan scanning software that will work with the 2100XL, windows 7 and many of these adpters
Scaner Umax power look 2100Xl
Windows-nya apa ? Biasanya ini terjadi karena drivernya nggak cocok sama windows. Misalnya driver installer nya hanya support sampai win vista atau XP saja, tapi di install di Windows 7 64-bit, pasti tidak akan jalan.
Semoga membantu.
