20 Most Recent Frigidaire FAFS4272LW Washer Questions & Answers
When the washer is turned on how do I get it to move from sensing?
Good Afternoon Friend, I understand that when your Frigidaire washer, model# FAFS4272LW, is turned on, you are having trouble with it moving from sensing. Your washer should be sensing how heavy the load is for a little bit and should then move on to the next point of the cycle. If not, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Once power is restored, try running any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful. -Best Regards- WP
6/19/2014 7:30:57 PM • Frigidaire... • Answered on Jun 19, 2014
Fafs42272lwo says door open when closed
Hello Craig, thank you for your post! I understand that the door of your Frigidaire washer (FAFS42272LW) indicates that it is open and your washer will not operate. Let's try resetting your washer by either unplugging it or flipping the household circuit breaker off. It is best to wait roughly ten minutes and then turn on your washer. Select a normal cycle and verify if your washer will start. If yourappliance will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website. Thanks for allowing me the opportunity to assist you! - Z
5/22/2014 9:44:12 PM • Frigidaire... • Answered on May 22, 2014
0answers
Fafs4272lwo parts diagram
go to youtube and look it up. Basically, you take the top off follwed by the control panel and the front. It is very easy to do.
11/26/2013 5:48:52 PM • Frigidaire... • Answered on Nov 26, 2013
I have a Affinity Series fafs4272lw. When I got
It easy to get out of balance if stuffed too much. The load sensing during the start rolls the clothes back and forth to balance the load. If its packed tight it won't do well.
10/16/2013 7:12:47 PM • Frigidaire... • Answered on Oct 16, 2013
My washer won't spin
Hello Michael Johnson - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Contact a professional to move forward accurately to properly diagnose and repair the unit.
1/8/2013 3:20:31 PM • Frigidaire... • Answered on Jan 08, 2013
How to replace the pump in a Frigidaire fafs4272lw washer
Hello - They pump looks like an elbow type connector and it is located underneath the unit on the bottom right. However, if you are trying to replace or repair the pump, contact a professional technician to move forward accurately since the information is not available due to liability reasons.
10/22/2012 5:54:31 PM • Frigidaire... • Answered on Oct 22, 2012
Where is the pump location
It may look like an elbow type connector and it is located underneath the unit on the bottom right. However, if you are trying to replace or repair the pump, you might need to get a professional technician.
9/17/2012 3:18:33 PM • Frigidaire... • Answered on Sep 17, 2012
Fridgidaire fafs4272lwo door open error
Make sure the latch is not broken on the door. Retry. If this continues contact a professional so the latch and door assembly can be diagnosed. Also check to see if the door is sagging down at all.
8/3/2012 7:13:44 PM • Frigidaire... • Answered on Aug 03, 2012
0answers
0answers
2answers
My Frigidaire Affinity washer makes a loud buzzing sound when you push the start button and will not start, what can I do
Good Morning Anonymous, this is Z. I am happy to assist you! I understand that your door indicates it is open and your dryer will not operate. Let's attempt resetting your dryer by either unplugging it or flipping the household circuit breaker off. It is good to wait approximately ten minutes and turn on your dryer. Select a normal cycle and verify if your dryer will start. If your dryer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, it would be advisable to contact an experienced appliance repair tech to assist further.
3/20/2024 3:24:35 AM • Frigidaire... • Answered on Mar 20, 2024
Frigidaire Front Load washer (25 yrs old) fills completely but does not spin for the wash cycle. Manual timer clicks and buzzes but drum does not spin nor does the timer advance.
Sure sounds like your timer has bit the dust. I'm not sure if the timer is still available. You have a great washer there. Good luck.
2/11/2024 4:24:20 PM • Frigidaire... • Answered on Feb 11, 2024
Frigidaire FAFS4272LW Washer Logo
24 questions posted
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
when washer turned get move from
  • Washing Machines
