20 Most Recent
Night Owl Optics 4 CHANNEL H264 DVR WITH 4 CAMERAS Questions & Answers
3 of the 4 camera's
honest answer, a rat chewed through all my cables ran in my in one day. but sometimes I do lose random cameras during continuous record mode.
How to change back a month for replay
Open your camera's software net viewer, using your IP address Port and password if necessary and proceed to the replay. Select/activate, when the Calendar view opens up. select the double << and go to the month that you need to.
Ac to dc power supply failure
The current capacity of the power supply may be insufficient for the camera. Use an ammeter to check the actual current draw of the camera.. Check the voltage of the power supply with a voltmeter at the camera while in operation. If the voltage is several volts less that it's rated output, then the supply needs to be able to replaced with one with a larger current capacity.
