20 Most Recent
LG Fathom VS750 Windows Phone Questions & Answers
How to download java apps in lg fathom
new need to first find out what version of windows your using after connect your phone to the internet and search for java it will give the link for windows mobile capability then you will be able to begin from there than you
How to update firmware of lg fathom v750??
Connect the phone to your computer Click on the "Start" button and then type "Update" into the search box. Click on "Windows Update" in the box that appears. Click on "Check for updates" and wait for the updater to scan your system. Click on the firmware update, if there is one. Click "Install Updates" if you have an update available to you and then click "Finish" when it is complete. Restart your computer.
GPRS SETTINGS FOR LG FATHOM
To activate GPRS in your mobile, you need to contact with your service provider. You may need to send some sms as per their rule to activate this service. After activation, generally they will send to the settings as per your handset.
You can only do this: Tap to select the GPRS authentication method. Tap None, PAP Authentication or CHAP Authentication.
Good Luck.
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
How can I hatd factory hard reset my LG 265 if I don't have my pin # nomore or forgot it .
- Turn the phone off.
- Press and hold the Power/Lock key (on the right side of the phone) and the Down Volume key (on the left side of the phone) at the same time.
- When the Factory data reset screen appears, release both of the keys.
- Use the Volume keys to highlight Factory data reset, then press the Power/Lock key to confirm.
- Use the Volume keys to highlight Yes, then press the Power/Lock key to confirm one more time.
- Your phone will perform a factory reset.
