20 Most Recent GE GTWN3000MWS Washer Questions & Answers
2answers
Plastic tab on back of backsplash assembly that holds timer in place has cracked
Might be able to fix with a zip tie through drilled hole or holes.
1/4/2024 8:50:46 PM • GE GTWN3000MWS... • Answered on Jan 04, 2024
Just moved the washer from one house to another and now it is making a metal on metal sound during aggitation
Sounds like the barrel got knocked out of alignment, or the motor bracket got bent. Try selectparts.com
3/8/2015 11:00:12 PM • GE GTWN3000MWS... • Answered on Mar 08, 2015
How can I remove clothing wrapped around bottom of agitator?
Try to pull out with pliers or Vice gip. May need to unwind around the agitator.
12/22/2014 2:10:49 AM • GE GTWN3000MWS... • Answered on Dec 22, 2014
Water not draining from machine
You either have a clogged or jammed up drain pump or a failed drain pump. p/n WH23X10030 IF the machine is full of water, drain the washer, remove power, remove the front cover of the washer by using a putty knife and pushing in between the top and front at the front corners about 3 inches in on both sides. The pump is on the lower right side. remove the pump from the washer, remove the 3 screws holding the pump motor to the body and remove anything that may be jammed in it. IF there is nothing in it, replace the pump assembly.
4/7/2014 6:15:26 PM • GE GTWN3000MWS... • Answered on Apr 07, 2014
0answers
We just purchased a washer (GTWN3000MWS), so
It defiently should agitate faster than that, the most probable thing causing that is a stripped agitator coupler. I have included a youtube video that shows step by step how to replace the coupler
http://www.youtube.com/watch?v=N26MCQKuXn0
Good luck
I hope this helps,if it does please give me a 4 thumbs up rating
Gene
3/29/2014 12:38:17 PM • GE GTWN3000MWS... • Answered on Mar 29, 2014
Fills Constantly
check the drain hose. Is it in the drain below the fill line of the washer? In other words -- the drain line should be above the level of the washer lid top and in the line about 4-6 inches
2/23/2014 8:15:44 AM • GE GTWN3000MWS... • Answered on Feb 23, 2014
0answers
0answers
Washing machine
Two types of balance involved with washers. First is the machine. Most new machines are self leveling with the front legs. If the machine is not level, shake the machine to change it orientation. Most times this is cause leveling. Second level is the load inside the machine. Clothes need to be distributed equally around the inside.
10/15/2013 5:57:39 AM • GE GTWN3000MWS... • Answered on Oct 15, 2013
I have a sheet stuck under the agitator of my GE gtwn3000mws. I've tried to use leverage to brute force the agitator out and it was a no go. Then I took off the top cup looking for the bolt to r
Remove the fabric softener cup, remove the plastic insert, then there is a 7/16th bolt you need to remove and the agitator will lift out.Here is a diagram of the tub assembly.11_13_2012_10_47_20_pm.gifRegards,Richard Rothhttp://appliancecafe.com
11/13/2012 10:48:05 PM • GE GTWN3000MWS... • Answered on Nov 13, 2012
GE GTWN3000MWS Washer Logo
51 questions posted
Top GE Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Virgil Watts
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
GE Washing Machines
  • GE Washing Machines
Most Popular Question
just purchased washer gtwn3000mws
  • Washing Machines
