20 Most Recent Whirlpool WTW4950XW Washer Questions & Answers
Hi I have whirlpool washer model# wtw4950xw0 seril# c10435937 It has given me trouble 2 moths after I bought it, 2nd hand but its about 3 yrs old. The load takes a long time and comes out wet and some
Sounds like the timer is acting up and not moving cycles. The part can be looked up and explained how to install it by checking on line for the appliance pro's or Sears Parts Direct for a parts breakdown and for pricing $50- 100.00 part, and 25 min. to install. You must unplug the washer before opening up the control head to get at the timer. The Timer is a ROTARY SWITCH that has many different functions It rotates on a clock mechanical motor at a certain speed. if it stops the cycle stops then nothing else happens unless the timer motor gets a burst of power to rotate again. Good Luck Bill
1/7/2018 6:14:05 AM • Whirlpool... • Answered on Jan 07, 2018
Filled but wont spin. brand new model wtw4950x
Sounds like a bad safety switch / lid switch. These new machines have magnetic proximity switches used on the lid to make sure the lid is closed before the machine will spin or cycle. Part is usually around 25.00 at appliance parts house for walk in customers. You would need someone familiar with electricity to replace it as it deals with 120 volts.
11/26/2017 5:35:50 PM • Whirlpool... • Answered on Nov 26, 2017
Wtw 4950 wont start
you need to get into diagnostic mode and check the error codes. This washer will give you couple of error codes but the first one is the latest. To check error codes How to Read Vertical Modular Washer VMW Error Code Display Calibrate/reset error How to Calibrate Top Load Washer After calibration/resetting the codes, check error code again that will give you correct error code. If there's no error possible problem is the actuator.
11/23/2017 4:26:41 AM • Whirlpool... • Answered on Nov 23, 2017
2answers
Whirlpool WTW4950XW Washer won't go past the sensing cycle.
It may be as simple as a defective door switch or even a clogged drain hose (the hose between the tub and drain pump. Here are some videos that may help you more than i can. This guy knows:http://www.youtube.com/watch?v=Aq7a3j7pFUM&playnext=1&list=PL5258B1D98A50745F
3/15/2016 9:42:39 PM • Whirlpool... • Answered on Mar 15, 2016
Wont drain and spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR http://www.youtube.com/watch?v=q942xn_2VXY Pl click if helped.
1/15/2016 6:03:18 PM • Whirlpool... • Answered on Jan 15, 2016
During wash and rinse cycles, the machine is humming as if the washplate was in motion but it is perfectly still. The laundry does not get cleaned even lightly soiled items. What's wrong? Thanks
Check the coupler on the motor. They break quite easily. The motor will spin but not the transmission.
10/29/2015 7:19:07 PM • Whirlpool... • Answered on Oct 29, 2015
Where can i get the tech data sheet to get error codes and fix whatever is wrong, cant afford to pay some technician.
http://applianceassistant.com/ServiceManuals/w10329932_l-84_whirlpool_vertical_modular_washer.pdf
1/10/2015 6:44:46 AM • Whirlpool... • Answered on Jan 10, 2015
0answers
What could cause my washer to have a loud noise on the spinning cycle
Clothes are unbalanced need to readjust clothes then close lead.
7/24/2014 2:06:50 AM • Whirlpool... • Answered on Jul 24, 2014
2answers
Why won't my washer spin all the water out
check drain assembly, cloughed drain
7/15/2014 11:42:24 PM • Whirlpool... • Answered on Jul 15, 2014
How to get top off to get acess to replace motherboard?
Make sure that all the screws are out of the back panel. Then the top control plate screws come out. Lastly the top then should just pop off.
6/21/2014 6:08:10 PM • Whirlpool... • Answered on Jun 21, 2014
What do I do when my Whirlpool dishwasher model #GU1500XTLQ3 overflows the air gap in the first two minutes of the "normal" cycle and water and runs all over the counter?
Sounds like the pressure switch is not cutting off. (1) Check to make sure it isnt shorted out, sometimes these fall out of the bracket and fall against the frame and short out. It is the piece that has a 1/4"clear rubber hose attached to it. (2) If everything passes the eye test then you may have a bad pressure switch. When the machine fills it slowly build pressure on the diaphram aka pressure switch and when it hits its set point it should open the switch and turn off the fill solenoid valve. The only way to check is with a multi meter. One wire on the switch should be live or have voltage and the other should be dead with no voltage. when full. During filling they would both be live. (3) You may have trash in the fill solenoid or a sticking fill solenoid.
5/28/2014 1:40:37 PM • Whirlpool... • Answered on May 28, 2014
0answers
Whirlpool WTW4950XW Washer Logo
130 questions posted
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
View Most Popular
  • Whirlpool Washing Machines
Most Popular Question
get tech data sheet get error codes fix
  • Washing Machines
