20 Most Recent
Motorola Mobility H730 Bluetooth Headset Questions & Answers
My samsung charge won't pair with bluetooth Motorola H730
First thing to do is make sure Bluetooth is on for BOTH devices . Second thing is to make Both devices Visible. Third is to Scan for nearby devices. You will need to know the 'device name' of each phone. When you find the other phone on one device, click on it & it should ask you to 'Pair device'. You should then hear an 'alarm' tone & get a message in a box. (sometimes you need to 'pull-down' this message from the top of the screen, like you do to get the settings or wi-fi status). It will ask you if you want to pair & then give you a 'Pairing code'. This is what you type into the phone. The other phone will then get this & ask if you want to pair. Say yes & the two phones are paired ONE WAY. You need to repeat the process for the phones the other way around, so that the phones are paired in both directions. Remember, every time you get the 'alarm' tone, to check your 'pull-down' to see if the connection code is hidden up there.! Telling it to you is more complicated than actually doing it.!!! Best of luck.
3/6/2018 3:47:51 PM •
Motorola...
Answered
on Mar 06, 2018
Can i listen to music on my motorola H730 bluetooth
It only took 5 years to get an answer, but since this headset is still sold and one of the best Motorola bluetooth headsets ever due to the voice clarity, durability, and the convenience of the flip microphone, as well as the very long battery life, someone may still be interested.Some android phones will play music and other sounds through this headset, but most will not. However, there is an app in the playstore called "Mono Bluetooth Router" that will allow headsets without A2DP to stream music and other sounds.
1/25/2017 1:25:39 AM •
Motorola...
Answered
on Jan 25, 2017
