20 Most Recent Homedics AR10 Air Purifier Questions & Answers
0answers
Homedics ar10
Be the first to answer 12/18/2013 10:23:58 AM • Homedics AR10... • Posted on Dec 18, 2013Be the first to answer
0answers
0answers
0answers
Ionic Pro Platinum TA750 Air Purifier. It will not turn on?
Question edited for clarity and toss in some CAPS. Question moved from Televisions category. Contact their Support for a warranty repair. https://www.envion.com/en/ta750 ..
12/12/2023 5:16:43 AM • Air Purifiers • Answered on Dec 12, 2023
I have an Afloia Air Purifier. The red light keeps blinking?
Question edited for clarity, dreadful spelling and typos. :>D Question moved from Televisions to Air Purifiers. Your air filter is dirty and needs cleaning.
Afloia Air Purifier Blinking Red - Repair, Care and ...
https://plentifulair.com > afloia-air-purifier-blinking-red... A flashing red light in all Afloia air purifiers indicates that the air filter needs to be replaced. Typically, in these air purifiers, the red light turns on ... ‎Why is My Afloia Air Purifier... · ‎How to Replace the Air Filter in... ..
11/7/2023 2:12:50 PM • Air Purifiers • Answered on Nov 07, 2023
Lost remote can I download one or an app for it please.
Question edited for clarity. Question moved from Cars and Trucks. From the maker https://www.google.com/search?q=Fresh+Air+by+Ecoquest+replacement+remote ..
11/7/2023 5:38:27 AM • Air Purifiers • Answered on Nov 07, 2023
My 20w aspectek bug zapper has stopped working, both bulbs off
Turn off the power button and Unplug the bug zapper. Turn off and Unplug Discharge Bent down and Remove Rotate and Replace the bulbs
8/27/2023 12:59:29 PM • Air Purifiers • Answered on Aug 27, 2023
What can I do to troubleshoot fuse blowing each time I turn on sanitizer - Breeze AT by EcoQuest
breaker blows or internal fuse ----either way need a multi meter to test for short
6/20/2023 1:21:36 PM • Air Purifiers • Answered on Jun 20, 2023
Rainmate Air Purifier. Why does my Rainmate not mist?
Question edited for clarity and correct maker name, plus (what it is). Question moved from Cars and Trucks. Usually just need cleaning and descaling
Cleaning Tips
Rainbow System https://rainbowsystem.com > Support You can even fill the Sprayer with ordinary household water and use it to mist your houseplants or clean your screen windows.
The Rainbow Rainmate: Does It Really Work?
GroundWaterGovernance.org https://www.groundwatergovernance.org > does-the-ra... Mar 13, 2022 - The simplest solution appears to be to change the water on a regular basis if possible. A home air purifier can be used as an aromatherapy ...
6/8/2023 3:47:31 PM • Air Purifiers • Answered on Jun 08, 2023
I need UV replacement BULB , I cant find one online
There are a few things you can try if you're having trouble finding a replacement UV bulb for your device online. One option is to check the manufacturer's website to see if they sell replacement bulbs directly. Many companies will also list authorized resellers on their website, so you may be able to find a replacement bulb from a trusted third-party seller. Another option is to try searching for the bulb using the model number of your device. This will help ensure that you're getting a replacement bulb that is specifically designed to work with your device. You can also try searching for the bulb using keywords related to the device, such as "UV water purifier bulb" or "UV air purifier bulb." If you still can't find the right replacement bulb, you may want to consider contacting the manufacturer directly to inquire about replacement options. They may be able to provide you with the information you need or point you in the direction of a trusted reseller. If online search not working you can try a local store that sell electronic part, Home improvement stores that carry a variety of lighting options may be able to help you find the UV bulb you need. Please do let me know the model number or application the UV light is used for, so that i could provide specific recommendations.
1/10/2023 4:58:20 PM • Air Purifiers • Answered on Jan 10, 2023
Homedics AR10 Air Purifier Logo
21 questions posted
Top Homedics Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Homedics Air Purifier Expert? Answer questions, earn points and help others
View Most Popular
  • Homedics Air Purifiers
Most Popular Question
instructions clean homedics hepa air
  • Air Purifiers
