20 Most Recent
Mr. Coffee BVMCPSTX91 Questions & Answers
The carafe for our Mr
Coffee is leaking past the silicon gasket. To get to the gasket, look for a round plastic plug in the top of the handle and pry it up. Under the plug is a screw that prevents the top of the carafe from twisting off. Remove the screw. Will now be able to unscrew the the plastic handle/top part from the stainless steel pot.
Between the 2 pieces is a silicon rubber gasket. Clean everything good. lubricate the gasket all over with "Plumbers Faucet and Valve Grease" available from Ace Hardware. It is waterproof and resists high temperatures.
Replace the silicon gasket making sure the groove fits over the top lip of the pot. Screw the handle/top part on the pot clockwise. It will only twist a short distance, but make sure it is very snug.
You do not need to replace the screw. This will make it easier to take apart if it leaks again. You might be able to get by with petroleum jelly instead of plumber's grease.
The CLEAN light has come
Have you ever wondered, 'how do I descale my
expresso machine?' First lets us understand what is exactly is scaling.
The build up of minerals inside the hot parts of your coffee machine or
espresso machine is commonly called lime scale. When lime scale
builds up inside the Espresso machine, it slows down the water flow,
reduces the boiler capacity and can prevent your coffee machine from
working properly. To keep your Espresso machine operational at full
order, it is important to descale it every three months. The time
intervals between descaling depend upon many factors. Quality of your
water and the amount of water running through the machine are the two
main factors that decide the frequency at which you should descale your
Espresso machine. The more you your machine, more often should you
descale it. In some cities, in conjunction with a water filter you can
use your coffee machine for a year or more without descaling at all. If
you use less water by drinking espressos you'll need to descale less
often than if you make cappuccinos.
Descaling products are widely available from stores
that sell coffeemakers and espresso machines. Be sure that the product
you buy to descale your Espresso machine is intended for this specific
use only. Before you descale your Espresso machine, always unplug it and
make sure that it is cold. Also, never immerse the appliance in water
and nor should you use abrasive cleaning products
or scouring materials on any part of your Expresso machine. In case
your Espresso machine does not come with a instruction guide or booklet,
then use a proper citric acid based descaling solution designed for
espresso machines. This should be mixed and prepared as per the
instructions on the bottle or packet. Once your Espresso machine has
been descaled properly you would not be left wondering, 'how do I
descale my expresso machine?', treat yourself to a great cup of coffee.
Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
HOPE THIS HELPS. MIKE (MR BEAN MAN) FROM FIXYA
Mr coffee beeps 3 times and thats all, no brew
3 beeps means plugged water line. Take off the bottom of the coffee maker with a small phillips head screwdriver. Use pliers (I used needle nose type) to remove the wire clamps holding on the silicone water tubes to the hot plate. In my case, the water line from the reservoir to the plate was clogged with something I couldn't see until I blew on the hose and it popped out, could have been scale, grounds etc Clean with vinegar. Back in service!
My mr. coffeemaker beeps 5 times and doesn't brew the coffee I just purchased this coffee pot last month aug 2014. what could be the problem
I see two problems that you've described.
First, you have a bad empty-reservoir sensor. Mine went out on my first Mr. Coffee within the first month also. The purpose of the sensor is to trigger the beeping to simply let you know when the coffee is done. The coffeemaker would normally work fine otherwise.
Second, you have a bad heating element. This is the core function of your coffeemaker and renders it useless for anything but a nice warming plate.
I recommend replacing the coffeemaker.
In the future, make sure you do not add water to the reservoir unless the coffeemaker has been turned of for at least five minutes. This will help prolong the life of the heating element.
The heating element will naturally degrade over time. But, it can incur sudden damage when the reservoir is refilled with water too soon - while the element is still hot. Because of the simple design, if the coffeemaker is on, then both the warming plate's heating element and the reservoir's heating element are on. So, after a brewing cycle is complete, the reservoir's heating element stays on. Without any in the reservoir to keep it cool, the heating element superheats. So, if water is put in the reservoir while the coffeemaker is on or before the element has adequately cooled, the sudden burst of steam from the water contacting the element can be quite violent.
