20 Most Recent
Brother MFCJ415W AllInOne Inkjet Printer Questions & Answers
No ink on paper
replace new cartridge, or try to clean the printhead, if problem still the same, something problem in your motherboard
How to replace ink cartridge Brother MFCJ415W
It's a fairly
straightforward process to replace the ink cartridge on the Brother MFC-J415W. All you need to do is open the ink cartridge cover, remove the color that you're replacing, and put in the new cartridge. Before putting in the new cartridge, however, you must turn the green knob on the yellow cap clockwise until it clicks. Then you put it in the printer and you should be good to go.
Brother MFC scanner bar is stuck
check the continuty in scanner cable to cis unit and check the continuity 2ends off scanner cable.
1.cable problem
2cis problem
