20 Most Recent
Brother DCPJ125 All-In-One Inkjet Printer Questions & Answers
Unable to print 4f
good day, unable to print 4f is printer head problem...replace new printer head
Brother DCP-J4110DW. Why is the ink absorber full?
The ink absorber box or flushing box is nearly full. These components are periodic maintenance items that may require replacement after a period of time to ensure optimum performance from your Brother machine. Because these components are periodic maintenance items, the replacement is not covered under the warranty. The need to replace these items and the time period before replacement is dependent on the number of purges and flushes required to clean the ink system. These boxes acquire amounts of ink during the different purging and flushing operations. The number of times a machine purges and flushes for cleaning varies depending on different situations. For example, frequently powering the machine on and off will cause numerous cleaning cycles since the machine automatically cleans upon power up. The use of non-Brother ink may cause frequent cleanings because non-Brother ink could cause poor print quality which is resolved by cleaning. The more cleaning the machine requires the faster these boxes will fill up. http://support.brother.com/g/b/faqlist.aspx?c=as_ot&lang=en&prod=dcpj4110dw_eu_as&tabid=2
Ink obsorver full ,menu ,mono upperkey 3times but not show further information
Remove the power source of the printer
Press the menu button .. Do not leave this button
wait a bit
Press 8
Okay
Press 0
Okay
wait a bit
Use the buttons START (Mono + Color) until it reaches the purge
Press this order figures
Okay
7
Okay
8
ok
ok
Wait until the value turn into zeros
Press exit
Press 9
Then 9
The printer will restart
End
EZZAT FROM EGYPT 002 01277289325
Unable init 4f
Try one or more of these options:replace the carriage PCB
,replace the head/carriage unit,replace the main PCB.
It does print but no ink coming out
Are the inks full? Have you tried the head cleaning utility in the printer drivers? If those don't work, get the inks out of the printer, soak the print heads in thinners and try the nozzle cleaning utility again.
If that doesn't work i think you may need some new print heads/ink
