20 Most Recent
HTC Chacha Smartphone Questions & Answers
How to download music
There are lots of online music downloader can complete this task. Just follow the below steps to do that.
YouTube MP3 is an easy-to-use online free internet music downloader. You don't need to download or install the software and you don't even need to register online. What you need to do is simply paste video URL into this free internet music downloader, then you can get MP3 file as you want. As it is platform-independent, it is not limited to use on different devices like Mac, Linux PC, Windows PC or phone. One thing to be highlighted is that all converted MP3 files are in high sound quality with the bit rate of 128 kBits/s. Now let's learn how to download music from internet for free.
1. Enter the website:
http://www.youtube-mp3.org/ .
2. Paste the video or audio URL into the search box, then click "Convert Video".
3. The site will start to download free music to computer from internet. After it finish downloading, you can tap on "Download" to download free music to computer from internet.
For more methods, check:
How to Download Music from Internet
Hi there, my HtC chacha was low on memory and
there are many free data and file recovery programs on the webyou could retreive themif you have not written or downloaded any and saved more to your hard drive
http://majorgeeks.com/Free_File_Recovery_d6792.html
Free File Recovery is a small and easy to use application that will help you to restore files that have been accidentally deleted from your computer. This includes files emptied from the Recycle bin as well as images and other files that have been deleted by user errordigital cameramemory cards or MP3 players. It will even bring back files that have been deleted from your iPod, or by bugs, crashes and viruses!
http://majorgeeks.com/NTFS_Undelete_d5532.html
NTFS Undelete is free software that allows you to recover deleted files. It recovers files directly from hard drive, and it will work even if you empty Recycle Bin. Before downloading NTFS Undelete, please consider the following: When you delete a file, its content physically remains intact on the media, but the occupied space becomes marked as free. Next file saved to the disk may overwrite the contents of the deleted file. It is very important to make sure that no application writes to the drive or partition where deleted file is located since every new file (even a small one) may overwrite the deleted file. hope this helps you
Volume increase on HTC Chacha smartphone
try this it might work, use another phone to call your phone and in the process of it ringing increase the volume by the volume side key and also do it for in-call volume
Pattern unlock
There are 2 solutions for your problem.For the first one you need to have your google account signed in on the phone. 1. Press the forgot pattern?2. Enter the username and passwordf of your account and sign in.3. You will be asked to create a new pattern.Now the solution if you don't have your google account on the phone.1. Remove the batter from the phone and wait couple of seconds.2. Put the batter back in the phone.3. Hold the VOLUME UP key on your phone and turn your phone ON at the same time.4. Now you will see a menu appear and you need to use the VOLUME DOWN key to move down on the menu until you get to CLEAR STORAGE and then you press the power key and then press the VOLUME UP key.5. The reset should now be complete.NOTE: Keep in mind that the second option will erase all the data that is stored on your phone.
My htc cannot start
- Make sure your battery is fully charged. Then remove battery, SIM card and any memory card you might have inserted. Clean all the metal (copper) contacts you find on the inside of the battery cover and SIM cover (if any) with methylated spirit on a cotton bud. Replace battery only and try restarting the phone. If successful, turn it off and replace SIM and try turning it on and off. If successful, do the same with the memory card. this can eliminate the problem. If none of the above is successful, you can try a factory hard reset however be mindful that all your data, apps and settings will be deleted and restored to factory state except the stuff you hace on your memory card and SIM, which will not be affected. I guess if you can not restart your phone anyway, there is not much else you can do, so you will only use what is not yours any more... :)
here is what you need to do:
Turn the power off. If your HTC Desire is frozen, pull the battery out and reinsert it
- Hold the Volume Down button
- Press and release the Power button
- You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
- Select Clear Storage by pressing the Volume Down button
- Now simply confirm your decision: Volume Up for YES and Volume Down for NO.
If you selected YES, all data including third-party applications will be deleted from the HTC Desire. Once the wipe is complete, the phone will reboot to its factory fresh state.
How to reset htc chacha cell when it is demanding email &p/w rejecting
Performing a factory reset using hardware buttons
If you can't turn HTC ChaCha on or access settings, you can still perform a factory reset by using the hardware buttons on HTC ChaCha.
- Remove the battery, wait for a few seconds, then reinsert the battery.
- Press and hold the VOLUME DOWN button, and then briefly press the POWER button.
- Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button.
- Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
Lock screen
do you have data via your 3g? if you do , you can use your google account to reset the lock pattern. Did you register on google play store?
Too many pattern attempts
the only thing you can do is a Factory Reset which will cause you to lose all your data, pictures, texts etc. Hold the Volume button down and the power button while the phone is on the off position and go to Hard Reset/Factory reset.
Keypad issue
needs a reflash from authorized repair center. (former HTC refurbisher)
