20 Most Recent Navman Tracker 5500i GPS Receiver Questions & Answers
the problem is that the controlling diode that checks LUX value is damaged (small clear window of minute proportion that adjusts screen brightness)
Navman Tracker... | Answered on May 29, 2017
Hello. If you still have the owners manual, you should be able to look in the language section and go throw it to know how to do the setting for the language you need. Good Luck.
Navman Tracker... | Answered on Jun 04, 2014
Its water ingress causing a short in the high voltage wiring PCB.
Open the unit with a 1.5mm allen key, unscrew the power/data cable sockets with a spanner and GPS antenna inlet with an 8mm socket (no antenna socket on i models) .
Where water has arced there will be burning black on the green PCB evident, cut the gold PCB flat wire and remove the section around the burn.
scrape a small amount of green off the gold flat PCB wire so you can solder a new wire to bypass the short. any 2.5mm insulated wire will do to bridge the gap you have just scraped away, there is plenty of room for a 1 inch wire.
Dry the unit and seal with silicone to prevent re occurrence.
Its a 2 hour repair requiring a high DIY soldering standard but off set it against the time it will take to reload you waypoints in a new plotter , its well worth the trouble.
DAKA
Navman Tracker... | Answered on Nov 29, 2013
http://www.navmanmarine.net/sitemap.html
Suggest you try this site. Good thing you can enlarge type on the computer.
I am having same trouble. I contacted Navman NSW and went through all the settings without result. It was suggested that the problem could be the external antenna, if not a fault in the machine. I have seen an after market antenna for about $19 so I might try that. It does seem as though the antenna is not talking to the Tracker.
Navman Tracker... | Answered on Oct 30, 2013
First of all the language was Finnish and not German. I managed to get a translation from Finnish to english for the word  kieli (Language).  Then i went to the system menu and selected kieli, then englanninkieli then pressed enter, this changed the language to english. I did not have to do a factory reset. Thank you for your trouble.
Regards Noel
Navman Tracker... | Answered on Oct 10, 2013
Contact the maker or Google for this item by model number.
Navman Tracker... | Answered on Dec 10, 2012
Navman Tracker 5500i GPS Receiver Logo
69 questions posted
Top Navman GPS Experts
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Navman GPS Expert? Answer questions, earn points and help others
View Most Popular
Navman GPS
  • Navman GPS
Most Popular Question
language setting
  • GPS
