20 Most Recent
Xerox DocuColor 5750 Printer Questions & Answers
Code 004
Code 004 means that the waste toner sump must be vacuumed.After that, reset DC 135 HFSI 9.836, go to DC 131 and reset to 0 positions 6058/6059/6060
The first code that appears is 001. If you had taken the proper actions, code 004 hadn't came.To find this code u should follow ""CALL FLOW" on page 1-3.
XEROX DOCUCOLOR 5750 PROBLEM
That means your waste toner sump is full and needs emptied and vacuumed.
For that problem, yeah its workt fixing.
The UV paper Im using to print labels is slightly
Job out your system to someone who prints directly to the bottle while you solve the other issue, which will not be solved to your satisfaction because "green" stuff doesn't stick, at least not yet, but green technologies exist for directly to the surface, so, get ahead.
Kind regards,
selk
Paper stickes to the roller when coming out
Your problem is one of the following:
- your sticker paper is not rated for use in your machine
- the paper is too old and the glue is not strong enough to go through your printer
- or your printer is too hot and loosening the glue before it is printed
