20 Most Recent
Xerox Phaser 8400N Thermal Printer Questions & Answers
Xerox 8400 Printer error code 37,002.47:181994
37,002.47: PEST Error - Printhead Left jetstack disconnect. The left jetstack is
not drawing the expected power from the supply.
Could be a connector came unplugged. Could also be ink spill on circuit board, causing it to go haywire.
How do I remove ink from a Xerox Phaser 8400 - I
I use a pen or something similar to work it up the loader and the stab it wit a push pin or paper clip to lift it out. You'll need to run some solid color pages to purge the ink from the printhead.
Error code 07007.40:135989 Phaser color printer
7,007.49: The process motor stalled while tilting the head.
Troubleshooting Procedure for 7,007 Error Code
Step Questions and Actions Yes No
1 1. Check the Printhead wire routing.
2. Remove the Printhead and inspect the
Printhead tilt and drive gears for ink
spills.
3. Re-route the wiring.
4. Clean around the gears and Printhead.
Did this correct the problem?
Complete. Go to Step 2.
2 To ensure Process Drive is correctly aligned,
homed, and free from damage, see “Homing
the Process Drive Train” on page 6-8.
Complete. Replace the
Process
Drive.
Out of alignment?
It actually is a problem with the drum. I have read that excessive oil on the drum itself can cause the issue. I have one that is doing the same thing. If you take it apart, you can try taking a soft lint free cloth and wiping down the drum. If that does not work, it will probably need a new drum.
