20 Most Recent
Xerox Phaser 6300DN Laser Printer Questions & Answers
How to install the phaser 6300 control panel
- Get a small flat head screw driver
- jam it on the bottom crack of the control panel and the machine then gently force the screw driver down and the control panel should pop up and it should come out.
- Then disconnect the harness and then connect the new control panel and just line up the holes with the plastic of the control panel and your finish
Good luck
No display on lcd screen, only solid red light, no
Does the printer print? if yes and the printer is still under warranty, send the printer in for warranty repairs. The interface card may be faulty or the interface robin cable if the printer is printing.
Xerox Phaser 6300DN is printing light black on
The laser window probably has either some toner or dust on it and needs to be cleaned. It will be under a shutter located in line with the drum.
It is less than 1/2 inch high and about 6 or 7 inches wide.
Clean that and your problem will go away.
White lines in printouts that contain cyan
It sounds like there could be dust or debris on the cyan laser window. To get to it, you have to remove the developer frame assembly. This is not recommended for beginners. Are you a service technician? If not, you may need to call one in.
Let me know if you need any more help or information.
