20 Most Recent
Xerox PE120i Laser Printer Questions & Answers
THERE IS A DISPLAY ON
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Sin cartucho
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Lsu error in dispaly
Hi
Your printers motherboard must be replaced it
the cost of it is to high
You better replace your printer
Pls vote me to keep me alive
How can i generate incoming call report ?
To print a report:
- Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
- Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
- Phone Book: Phonebook list
- Sent Report: Sent fax report
- RCV Report: Received fax report
- System Data: System data list
- Scheduled Jobs: Scheduled job information
- MSG Confirm: Message confirmation
- Junk Fax List: Junk fax number list
- Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
- Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
- Sent Fax Repor: This report shows information of the faxes you recently sent.
- Received Fax Report: This report shows information of the faxes you recently received.
- System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
- Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
- Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
- Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
- Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
- Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
