20 Most Recent
Xerox 1 YEAR ON-SITE SERVICE AVAILABLE ON AN ANNUAL BASIS FOR THE PHASER 8500 / 8550. (095205219357) PC Notebook Questions & Answers
My xerox pro 420 have
The U-9 code means the main control unit/switch board has a problem, replace the board.
Xerox 214 dc
It means the cartidge alignment is dis-balanced. So you need to fix it and may be re-fill cartidges also.
Xerox 214
That is a fuser overheat message.
You can try this. Enter diagnostics. To do that turn the machine off, then press and hold down the ( 0 ) zero button while you turn the power on.
Once the machine comes on in diagnostics. Enter code 40 1and press start to see if it clear the fault.
That is enter 40 press start then 1 press start.
If that does not resolve the code you need to replace the fuser.
Xerox workcentre 3345 paper jam in tray1
If you've modified one of the trays and still encounter the same error, it's worth checking if there are any obstructions in the paper path or if the default paper type and color settings need adjustment.
Remove Jammed Paper From Tray 1:
First, remove any paper from the Bypass Tray.
Grasp both sides of the Bypass Tray and pull it straight out of the printer.
Next, pull out Tray 1 until it stops. To remove the tray, lift the front of it slightly, then pull it out of the printer.
Check for any jammed paper and remove it.
Also, make sure there's no crumpled paper left in the tray or jammed inside the printer.
If you have Tray 2 (optional), check it as well.
Insert Tray 1 back into the printer and push it all the way in.
Fully insert the Bypass Tray as well.
Confirm the paper settings if prompted.
Try your job again.
Power the Printer Off then On:
Press the Power/Wake button on the printer control panel.
Choose "Power Off" to turn off the printer.
Wait for a few seconds, then press the Power/Wake button again to turn it back on.
Retry your print job.
Replace the Paper Feed Roller (if needed):
If the issue persists, consider replacing the paper feed roller. Refer to your printer's documentation for instructions on how to do this.
If the problem continues, contact Xerox support.
