20 Most Recent Zebra 105Se Thermal Printer Questions & Answers
My zebra 105se printhead light is blinking yellow
The printhead light blinking usually means that the printhead is open. Is this happening with the printhead locked down ? If this is the case, the problem is with printhead open flag. It is located on the electronic side of the printer. You need to take off the side cover (with printer turned off). The lever that raises and closes the printhead is attached to a shaft (the pressure toggle is also on this shaft). Follow this shaft to the electronic side of the printer.
At the end of this shaft, there will be a black rectangular piece of plastic. This is the head open flag. When printhead is closed, the flag is positioned at the six o'clock position between two optic sensors. When the printhead is opened, the flag rotates clockwise to about the nine o'clock position. If the HEAD OPEN message appears when the head is closed, then the flag is out of position, usually it has become loose on the end of the shaft.
The flag is attached to the end of the shaft with an allen screw. Make sure the head is closed, position the flag to the six o'clock position between the two sensors and tighten the screw. this should take care of the problem.
Hope that helps !
5/2/2018 7:34:51 PM • Zebra 105Se... • Answered on May 02, 2018
I notice there is the
in XP every printer driver has DEFAULTS. These are very limited and its up to the DRIVER what things it lets you Default. right click any printer in the printers list and choose properties, then click advanced, then click the Printing Defaults button, and make your changes and apply them. if it does not let you choose what you need to then its the fault of the driver for the printer.
12/12/2017 2:02:26 PM • Zebra 105Se... • Answered on Dec 12, 2017
My Zebra 105Se printer keeps printing blank labels
There are several reasons why this could be happening. If the computer accessing the printer changed then I assume the new computer was recently set up with software to send print information to the printer. I would start with simple calibration and move from there. Zebra Technologies 105SL Printer Calibrating the Printer With Video
4/20/2015 5:58:50 PM • Zebra 105Se... • Answered on Apr 20, 2015
3answers
Driver for Zebra 105se
Hi spydo... Zebra 105se drivers (xp/vista/win7/win8) can be found at driverupdate us It will take 2 mins from you to install... I hope I have helped you... enjoy
11/17/2014 2:20:57 AM • Zebra 105Se... • Answered on Nov 17, 2014
My zebra 105Se keeps printing blank labels.
Do the labels come out right when you print locally? That is the first thing to see. Serial devices over a network are tricky. Baud rate and what to do with CR LF, stop bits, parity etc. need to be right.
6/4/2014 8:33:15 PM • Zebra 105Se... • Answered on Jun 04, 2014
Skipping labels
Do you use adhesive labels? It looks like the printer is unable to make the difference betwen the labels. Verify that the printer it's not set on Continuous mode for the media type. Verify if there is any label (or pice of label) stiked on the upper media sensor (gap sensor). You can locate the upper media sensor using the User Manual (page 74). There is an User Manual available for download from Zebra website. You will find there precious information. The manual is very explicit and you will learn how to maintain your printer and how to troubleshoot some common errors. Clean your printer, assure to put the supplies on the right path, close the printhead and press Pause to enter in Ready state. You can clean the sensor with an coton cloth dampened into isopropylic alcohol. Here is the link to user manual: http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/105sl-ug-en.pdf
6/3/2014 12:48:21 PM • Zebra 105Se... • Answered on Jun 03, 2014
Advancing blank labels inbetween printing
6/3/2014 11:32:04 AM • Zebra 105Se... • Answered on Jun 03, 2014
Darker print
Enter the Setup Menu from control panel and modify the Darkness value. You have to increase the value and then Save the changes and exit the menu. On control panel Buttons you find the role of each button in the control panel. You can use the User Manual. There is an User Manual available for download from Zebra website. You will find there precious information. The manual is very explicit and you will learn how to maintain your printer and how to troubleshoot some common errors. Eventually clean your printer, assure to put the supplies on the right path, close the printhead and press Pause to enter in Ready state. http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/105sl-ug-en.pdf
6/3/2014 9:15:32 AM • Zebra 105Se... • Answered on Jun 03, 2014
Darker printe for 105se printer
Enter the Setup Menu from control panel and modify the Darkness value. You have to increase the value and then Save the changes and exit the menu. On control panel Buttons you find the role of each button in the control panel. You can use the User Manual. There is an User Manual available for download from Zebra website. You will find there precious information. The manual is very explicit and you will learn how to maintain your printer and how to troubleshoot some common errors. Eventually clean your printer, assure to put the supplies on the right path, close the printhead and press Pause to enter in Ready state. You can try to tighten the 2 pressure screws from the top of the printhead assambly. This will bring the printhead surface closer to the platten roller. The screws can also be moved left and right and correct the wear of the platten roller. Here is the link to the English version of User manual: http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/105sl-ug-en.pdf
6/3/2014 9:14:25 AM • Zebra 105Se... • Answered on Jun 03, 2014
Why zebra printer supplies panel blink red light
The printer it is in error state? Any other LED it's blinking or lighted? Do you have any message on display? Please verify if the supplies are on the correct path. Do you use adhesive labels? Verify if there is any label (or pice of label) stiked on the media sensor. You can locate the media sensor using the User Manual. There is an User Manual available for download from Zebra website. You will find there precious information. The manual is very explicit and you will learn how to maintain your printer and how to troubleshoot some common errors. Clean your printer, assure to put the supplies on the right path, close the printhead and press Pause to enter in Ready state.
6/3/2014 8:31:29 AM • Zebra 105Se... • Answered on Jun 03, 2014
What is the cause of supplies blinking red color
6/3/2014 8:30:12 AM • Zebra 105Se... • Answered on Jun 03, 2014
Drivers download
Hello, You can download your Printer Drivers from the below link : http://www.zebra.com/us/en/support-downloads.html
12/14/2013 9:38:34 AM • Zebra 105Se... • Answered on Dec 14, 2013
0answers
0answers
Calibration
Be the first to answer 11/27/2013 4:30:50 PM • Zebra 105Se... • Posted on Nov 27, 2013Be the first to answer
Zebra 105Se Thermal Printer Logo
124 questions posted
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ExpressFiX
ExpressFiX
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Zebra Office Equipment & Supplies
Most Popular Question
driver zebra 105se
  • Office Equipment & Supplies
