20 Most Recent Zebra P330i Thermal Card Printer Questions & Answers
2answers
Zebra P330i Printer not counting the YMCKO ribbon correctly
!RIBLEN - - - - Get number of remaining panels on ribbon
Send the command !CSA_0
Send the command !CSA_1
4/29/2018 11:07:25 AM • Zebra P330i... • Answered on Apr 29, 2018
0answers
2answers
How do one resolve and
The P430 and the P330 are similar, P430 print both sides from the card, and the P330 just print one site, but the commands to send are the sane. Please try !SA command from the driver.
6/9/2017 2:43:52 PM • Zebra P330i... • Answered on Jun 09, 2017
Not printing full card
it's possible that some elements from the printhead are damage, you will have to replace the printhead. Try to print the demo card, if still happen, possible printhead.
3/12/2017 12:35:49 PM • Zebra P330i... • Answered on Mar 12, 2017
Zebra p330i prints half blank
Printhead or ribbon sensor need calibration, please send the comand !SA from the driver.
3/12/2017 12:29:18 PM • Zebra P330i... • Answered on Mar 12, 2017
Zebra 330i prints in pink or black on test print. New ribbon fitted.Cleaned and calibrated.
Either your print-driver settings don't match the ribbon installed, or you have a bad ribbon sensor. Check your driver settings via the Windows printer center screen (Win7: Start Button => Devices and Printers; WinXP: Start Button => Printers and Faxes); locate your Zebra printer, then right-click on it and select "Printing Preferences". Locate the tab for the ribbon setting, and ensure the setting here matches the ribbon you have loaded. NOTE - you must have Windows administrator rights for your Windows log-in ID to make any changes to the driver settings. Contact your network administrator if you do not have these elevated privileges, and they can log in and make any required change for you.
8/21/2015 7:41:21 PM • Zebra P330i... • Answered on Aug 21, 2015
4answers
My zebra card printer p330 i donbt recognized the
The P330i is not supposed to work with the YMCK color ribbon, you should use the YMCKO 800015-440 color ribbon.-- The Pros at www.DiscountIDStore.com
5/28/2015 9:49:25 AM • Zebra P330i... • Answered on May 28, 2015
P330i gives out of ribbon error. When completing
The printer uses three sensors in relation to the ribbon. The RFID (chip on ribbon). When you go into the printing preferences for the printer it should detect any color ribbon, and say ribbon type changed to (ribbon type). If so both the ribbon and RFID sensor are working properly. Then there is the color ribbon sensor, which has the blue and amber LED's, and is used to detect the panel of the ribbon. Thirdly the flag sensor which is on the back end of the supply reel, to detect the ribbon turning. . Additionally, CALIB command has never worked for me. !SA is an auto self adjustment for multiple sensors. additional you can use !CSA 0 without ribbon in machine, then run !CSA 1 with a ribbon (color ribbon is a must with any calibrations). You can also run !SAP 0 for card sensors !SAP3 for mag encoder card sensor. !SAP 1 for ribbon calibrations. if all else fails, you can manually set the ribbon by using !CSA 5 70 120. Please remember these commands are for genuine zebra I Series printers, and that they are case sensitive, and spaces are present. If none of the above corrects the issue you may need to replace one of the three sensors, the daughter board, or possibly the main logic board.
10/28/2014 6:52:15 AM • Zebra P330i... • Answered on Oct 28, 2014
0answers
Printer does not print to the edge of the card
calibrate with ribbon 800000-440
6/1/2014 2:13:34 AM • Zebra P330i... • Answered on Jun 01, 2014
Can i use Zebra i-series YMCKO ribbon in Javelin i-series printer
hi, not sure, but they have diferent ribbons, 800000-440 or -415 .... try difirent ones
5/14/2014 10:41:30 AM • Zebra P330i... • Answered on May 14, 2014
Zebra P330i Thermal Card Printer Logo
186 questions posted
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ExpressFiX
ExpressFiX
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Zebra Office Equipment & Supplies
Most Popular Question
use zebra 330i hp thin client pc
  • Office Equipment & Supplies
