20 Most Recent Zonet PCMCIA 56K V.92 Modem (ZFM5600-CF) (MDMZN5600CF) Questions & Answers
Zonet 56K/V.92 FaxModem ZFM5621LT
There's a simple step by step guide here. How to Add Fax Modem to New Computer
2/2/2018 6:09:44 PM • Zonet PCMCIA 56K... • Answered on Feb 02, 2018
Connection speed
the usual maximum speed for a v92 dial up modem is around 48-52kbps, although sometimes the way windows calculates the speed can be different, showing higher speeds than is actually possible, hence the 115k that shows when connected. The only way you can get faster download speeds is to download the 'Onspeed' software which compresses pictures etc to enable twice the download speed.
8/22/2007 8:09:18 PM • Zonet PCMCIA 56K... • Answered on Aug 22, 2007
2answers
Very choppy video
Back when P4 systems were common, the hard drive interfaces were quite marginal for video processing and techniques to force the capture to faster devices (like a RAM drive, or now SSD drive, or SCSI interface to high end striped drives) were used to smooth the video capture. I have had good luck with SATA3 interface SSD's for capturing video, but continue to use a drive other than the one I boot from so windows doesn't mess up the frame rate.
5/18/2017 1:30:47 AM • Zonet Computers... • Answered on May 18, 2017
How can I set a password on my Internet with a zonet modem
First: GENERAL ROUTERS RESETING Second: http://www.fixya.com/support/r7900574-general_router_setup
5/12/2015 6:16:51 PM • Zonet Computers... • Answered on May 12, 2015
ZSR4124WE
POORLY supported routers made in China. STRONGLY recommend disposing of this device and obtaining one from a better vendor that supports it's products i.e.: Cisco, 3Com, etc...
7/23/2014 7:22:48 PM • Zonet Computers... • Answered on Jul 23, 2014
Setup cd for zonet zpw4000
Contact seller or company that makes it. May be a download item on maker's site.
7/23/2014 3:31:52 PM • Zonet Computers... • Answered on Jul 23, 2014
0answers
Zonet
Be the first to answer 7/20/2014 3:02:42 AM • Zonet Computers... • Posted on Jul 20, 2014Be the first to answer
Larger size downloads stall out - windows 7 router is ZSR1124WE
You could try Getright software, but most likely you are having connection problems (low bandwidth or high error rates). Problem is not likely in the router unless your wireless signal strength is very low.
6/8/2014 6:45:35 PM • Zonet Computers... • Answered on Jun 08, 2014
Change ip address of my zonet router from 192.168.0.1 to 192.168.10.1
It's not a big deal. The base address may vary for various routers, and you can adjust it according to your current network configuration (I mean other TCP strings)
4/24/2014 10:37:01 AM • Zonet Computers... • Answered on Apr 24, 2014
0answers
0answers
No vga by pushing port buttons
In order to fully answer your question, a number of needful things must be inspected, reinstalled, confirmed, & tested:
  1. Reset. Try the reset button. You could use a paper clip to reach the reset button through the pin hole in the lower front left of the Zonet KVM unit.
  2. Inspect connectors. Each data/input/power connector/port requires all of its pins to be present & straight for full functionality.
    1. Inspect the entire length of each cable & cord to ensure that each has no damaged area.
    2. Seat each connector in the appropriate port of a computer that will be accessed via the KVM unit.
  3. Electricity. Inspect all affected devices & confirm that each has sufficient, uninterrupted electricity.
    1. It is possible for a Zonet KVM unit to display channel lights without direct power to the unit, but you should confirm that the unit is getting sufficient, uninterrupted electricity-directly through its own power cord. Unplug the KVM power cord & every connector & reseat each one (this performs a power reset on the KVM unit)-making sure that each connector is in the correct location (not just where it originally was). Thus, make sure that the keyboard, video display (monitor), & mouse are on the output side.
    2. Press the power button on your monitor. If it does not turn off the monitor's power status light (Off/On/Standby), then remove the power cord from the monitor & reseat it-to reset the monitor's hardware. If it does not turn on the monitor's power status light, then the monitor is either not getting enough electricity or it has a malfunction which requires troubleshooting & fixing (possibly through a fixya.com thread for that monitor model).
    3. Unlike USB devices, PS/2 devices usually require device connection prior to turning on that device. With that said, connect the keyboard & mouse KVM channel cable connectors to the computers & then turn on those computers that you intend to display through the KVM-connected monitor & then turn on these computers.
    4. Any computer that does not turn on has an issue that requires resolving (just like a monitor that would not turn on).
    5. Sometimes a keyboard/mouse interface issue can be resolved by replacing that interface device.
  4. The KVM Unit. When all else properly connects & performs, what does not properly connect & perform has the issue &, hopefully, that can be repaired without having to replace it.
1/19/2014 7:18:05 PM • Zonet Computers... • Answered on Jan 19, 2014
Reset wireless password
Do a factory reset - usually a 'secret button' hidden on the back - default router passwords can often be found on the net.
1/19/2014 1:55:46 AM • Zonet Computers... • Answered on Jan 19, 2014
Zonet PCMCIA 56K V.92 Modem (ZFM5600-CF) (MDMZN5600CF) Logo
2 questions posted
Top Zonet Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Zonet Computers & Internet
Most Popular Question
zonet 56k v 92 faxmodem zfm5621lt
  • Computers & Internet
