20 Most Recent Zoom (3090-72-00) Modem Questions & Answers
No 64bit driver for Zoom 3090
The driver files for Model 3090 will not work with Model 3090A/3090AF, or vice versa. So This driver supports WINDOWS VISTA 64-BIT systems only. If you are using Vista 64 bit, Go to http://www.zoomtel.com/techsupport/dial_up/3090.shtml
1/29/2014 4:48:48 PM • Zoom... • Answered on Jan 29, 2014
0answers
Bought new usb zoom external modem for my windows xp
Best thing for you to do is go on the manufacturer site ... of the modem and go under support and download the latest drivers and software for the modem. There has probably been some updates since the modem has been sitting on the store shelf that address your problem installing the software. I hope this helps.
Sincerely cdixon18,
The Man Inside The Machine
5/12/2009 1:33:12 PM • Zoom... • Answered on May 12, 2009
Hard drive recovery Hi I have a zoom 16 track multrack studio model 1608 I've accidentally deleted the hard drive unfortunately no back up is it possible to recover the hard drive
Most licensed and professional recovery software will recover files from RAW/APFS and FAT/NTFS formats. Take it to a software recovery professional or purchase the software and do it yourself. You cannot recover a hard drive if it has been written on since deletion.
7/22/2023 7:32:26 PM • Zoom Computers &... • Answered on Jul 22, 2023
3095's won't work with mac lion
The Brother HL-3095CW is a color laser printer that is not natively compatible with Mac OS X Lion. However, there are a few ways to get the printer to work with your Mac:
  • Download and install the Brother printer driver for Mac OS X Lion from the Brother website.
  • Use the built-in AirPrint feature in Mac OS X Lion to print wirelessly to the Brother HL-3095CW.
  • Use a third-party software such as Gutenprint or CUPS to add support for the printer to your Mac.
  • Use a print server to connect the printer to your network and make it available to your Mac.
It's important to note that this printer was released in 2009 and Brother's support for this device and Mac Lion will be limited. It's recommended to check Brother's website to see if the printer model is compatible with the latest Mac OS version and the support for the printer model. If you continue to have issues with getting the Brother HL-3095CW to work with your Mac, it would be best to contact Brother technical support for further assistance.
1/12/2023 3:00:39 PM • Zoom Computers &... • Answered on Jan 12, 2023
Can zoom HD 8 files be transferred to zoom R 16? If so, how?
Yes, it is possible to transfer files from a Zoom HD 8 to a Zoom R 16. To do this, you will need to connect the HD 8 to the R 16 using a USB cable. Then, on the R 16, you can use the "Import" function in the "Recording" menu to transfer the files from the HD 8 to the R 16. Here are the steps to transfer files from a Zoom HD 8 to a Zoom R 16:
  1. Connect the Zoom HD 8 to the Zoom R 16 using a USB cable.
  2. On the Zoom R 16, press the "Menu" button and navigate to the "Recording" menu.
  3. In the "Recording" menu, select the "Import" option.
  4. Use the arrow buttons to select the files you want to transfer from the HD 8 to the R 16.
  5. Press the "Enter" button to start the transfer process.
  6. Wait for the transfer to complete, and then press the "Exit" button to return to the main menu.
  7. Disconnect the Zoom HD 8 from the Zoom R 16, and the transferred files will be available on the R 16.
Note: The exact steps for transferring files from a Zoom HD 8 to a Zoom R 16 may vary depending on the specific models and firmware versions of the devices. Consult the user manuals for both devices for more detailed instructions on how to transfer files between them.
12/10/2022 2:43:27 AM • Zoom Computers &... • Answered on Dec 10, 2022
How to I resolve a no account issue with Zoom?
Sign in here https://zoom.us/signin If you were on a computer, it may be a Windows System Error How to fix the issue reported by error code "Error 1105" Windows 11, 10, 8, 7 Meaning of error code "Error 1105" Error code "Error 1105" is an issue name that contains details of the malfunction, including why it occurred, which system component or application malfunctioned, along with some other information. The numerical code in the issue name usually contains data that can be deciphered by the manufacturer of the component or application that malfunctioned. The issue with this code may occur in different locations within the system, so even though it carries some details in its name, it is still difficult for a user to pinpoint and fix the issue cause without specific technical knowledge or appropriate software. Causes of error code "Error 1105" If you have received this warning on your PC, it means that there was a malfunction in your system operation. Error code "Error 1105" is one of the issues that users may get as a result of incorrect or failed installation or uninstallation of software that may have left invalid entries in system elements. Other potential causes may include improper system shutdown, such as due to a power failure, someone with little technical knowledge accidentally deleting a necessary system file or system element entry, as well as a number of other factors. Or Zoom Error Zoom error code 1105 https://support.zoom.us > en-us > articles > 571982141...Apr 22, 2022 - If you are receiving error code 1105, please contact Zoom Support for troubleshooting assistance. Please provide the following:.
8/4/2022 10:49:46 PM • Zoom Computers &... • Answered on Aug 04, 2022
How to increase the size of screen I mean how to zoom the screen
Impossible to answer without a full make and model, but in a Zoom Computer it would be Settings - System - Display - Display Resolution.
11/29/2020 11:01:22 AM • Zoom Computers &... • Answered on Nov 29, 2020
2answers
My windows media player message
11/13/2019 3:18:45 AM • Zoom Computers &... • Answered on Nov 13, 2019
2answers
Zoom text is not working on email. It is working on google. it is so small I cannot read it.
Right, different mail softwares have different option to zoom. If it is outlook, Please see if below link help you : https://www.slipstick.com/outlook/adjust-outlooks-zoom-setting/
11/3/2019 11:01:23 AM • Zoom Computers &... • Answered on Nov 03, 2019
Xfinity can't increase download speed through my zoom 5350
the problem is not the router, it is the service. Call your internet service provider and see if they can offer you a faster internet connection.
6/5/2019 3:37:21 AM • Zoom Computers &... • Answered on Jun 05, 2019
Why can i only open zoom from my browser
it depend on what browser you use, but it always on the menu of tools on the "zoom" if is a Mac, just like to make zoom on your phone on the touchpad of the macbook.
4/5/2019 1:38:22 AM • Zoom Computers &... • Answered on Apr 05, 2019
Zoom G5 not working can repair?
probably you can repair it take it to repair shop
11/7/2018 8:39:12 AM • Zoom Computers &... • Answered on Nov 07, 2018
My cemera is working properly.Whan I make minimum zoom it's working.But whan I make full zoom than show "The zoom did not operate normally......etc." What can I do?????
Suggest refer to owner's manual trouble shoot section. Any internal problems and modern small electronics cost more to repair than they are worth. Suggest buy a new one.
3/21/2018 6:45:03 PM • Zoom Computers &... • Answered on Mar 21, 2018
MODEM
Modems audio, and network cards are notorious for not being recognized by Windows. If you have an EXE file for install, insert the disc, and click on install. You may need to okay the installation. If this does not work, and since the computer is not recognizing it, I would go to Control Panel, then find Hardware manager. Your modem should be there with a yellow icon over or by it. Right click on it, and select install driver. Then navigate to the disc, and then select the INF file for it.
1/3/2018 12:19:49 AM • Zoom Computers &... • Answered on Jan 03, 2018
Zoom (3090-72-00) Modem Logo
Popular Tags
3 questions posted
Top Zoom Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
ExpressFiX
ExpressFiX
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Zoom Computers & Internet
Most Popular Question
no 64bit driver zoom 3090
  • Computers & Internet
