20 Most Recent 2011 Xingyue Xy260T4 Questions & Answers
Replace headlight bulb 2011 Xingyue Xy260T4
Yes.
5/1/2021 7:07:58 PM • 2011 Xingyue... • Answered on May 01, 2021
Service manual
Haines publish Chinese/Taiwan motorcycle Service Manuals. Contact Haines & ask them directly, if no luck, try & Google your problem for solution. There are motorcycle forums also. Hope this is some help.
7/8/2014 10:30:22 AM • 2011 Xingyue... • Answered on Jul 08, 2014
I do not have any ground signal coming from cpi to the ignition coil. Is this a bad cpi, or is something not working prior to the cpi causing the loss of signal?
maybe a bad ground inspect wiring and harness unit and the coil can be tested the library has service manuals on asian bikes that xplain details and troublshootn may need bike scanned at a private shop
7/6/2014 3:28:29 PM • 2011 Xingyue... • Answered on Jul 06, 2014
I have a scooter, XZ260T-4 whcih does not get any fire to the ignition at the spark plug. All seems to be right otherwise. Any suggestions?
Hi
It could be a faulty ignition coil or wires, broken high tension spark plug lead, faulty spark plug or the spark plug gap. If there's a distributer or points involved check for cracks or point hap settings. You need to eliminate each one in tutn to find the fault.
6/26/2014 2:38:43 PM • 2011 Xingyue... • Answered on Jun 26, 2014
I have a xingyue xy260t-4 with 2000 miles on it. I
My scooter dose the same with the gas gauge it seem to be the reading gauge in the tank if you fill it up and ride it for about 40 miles you will see the gauge go up to full as the gas starts to go down.
8/4/2011 1:06:49 PM • 2011 Xingyue... • Answered on Aug 04, 2011
Hi, I have a Xingyue
IT'S FLOODED, CHANGE YOUR OIL' TAKE THE PLUGS OUT SPIN IT OVER A FEW TIMES THEN SQIRT SOME OIL DOWN THE PLUG HOLES, SPIN IT AGAIN THEN THROW YOUR PLUGS IN, IT SHOULD START, IT WILL SMOKE A LITTLE FOR 10 OR 15 MINUTES BUT IT WILL STOP. GOOD LUCK!
7/28/2011 1:26:07 AM • 2011 Xingyue... • Answered on Jul 28, 2011
Hi my scooter vog 260
the fuses is in the glove box at the very back
1/15/2014 2:32:52 AM • Xingyue FLHR... • Answered on Jan 15, 2014
0answers
Fuse box on 150
Be the first to answer 9/27/2015 4:13:56 AM • Xingyue... • Posted on Sep 27, 2015Be the first to answer
I'm getting terrible mileage on my Xingyue 150 cc and recently lost power (maxs at less than 40mph). Any ideas?
change air filter and spark plug,clean out exhaust
3/3/2015 5:59:16 PM • Xingyue... • Answered on Mar 03, 2015
Is there a manual for xingyue scooters ?
If it's one of the common engines, like a 139QMB for example, you can at least get a manual for the engine. http://www.49ccscoot.com/manuals/manuals.html
6/17/2014 12:21:19 PM • Xingyue... • Answered on Jun 17, 2014
Xy 400 overheats why
Did you find the problem Im having the same issue, can it be the cooling liquid hose that passes near the exhaust pipe?
4/17/2014 11:05:31 AM • Xingyue... • Answered on Apr 17, 2014
0answers
What causes my fat boy to idle just fine but fall on its face back fire and try to shut down while riding
Some common causes and potential solutions: Air/Vacuum Leak: If your Harley develops a vacuum leak in its air intake system, the air-fuel mixture becomes too rich. This can cause frequent stall outs, especially after the bike warms up. Vacuum leaks often occur due to dried-out or cracked air intake boots, faulty gaskets, or worn-out carburetor seals. When air escapes from the intake system, the fuel fills the empty space in the combustion chamber, altering the air/fuel ratio and negatively impacting combustion. Severe vacuum leaks can lead to excess fuel flowing into the exhaust system, causing backfiring and stalling while riding. Clogged Fuel Tank Filter/Fuel Injectors: A blocked fuel tank filter (due to coagulated fuel, moisture, dirt, or corrosion) impairs fuel flow, resulting in a lean air/fuel ratio. On fuel-injected Harleys, clogged fuel injectors produce similar symptoms. Regular maintenance, including cleaning and inspecting fuel filters, helps prevent these issues. Faulty Cam Chain Tensioner: A malfunctioning cam chain tensioner can affect engine timing and cause stalling. Regular checks and replacements are essential to avoid this problem. Faulty Cam Position Sensor: The cam position sensor plays a crucial role in ignition timing. If it malfunctions, it can lead to stalling and backfiring. Clogged Air Cleaner: A dirty air cleaner restricts airflow, affecting combustion efficiency. Regularly clean or replace the air filter to prevent this issue. Ignition System Failure: Faulty ignition components (such as spark plugs, ignition coils, or wires) can cause misfires, backfires, and stalling. Inspect and maintain these parts regularly. Compromised Battery Terminal Connection: Poor battery connections can disrupt electrical flow, affecting the ignition system. Ensure clean and secure battery terminals. Remember that diagnosing and addressing these issues may require professional assistance. Regular maintenance and timely repairs can keep your Fat Boy running smoothly on the road.
4/21/2024 6:14:37 PM • Motorcycles • Answered 3 days ago
Engine number location on a 2007 c90
Honda C90, or Suzuki C90? all questions need full 'year make model'. Google it plus 'engine number location'. ..
4/21/2024 2:56:52 AM • Motorcycles • Answered on Apr 21, 2024
Need circuit diagram for ARLEC 15e 6-24Volt 15Amp Electronic battery charger OR their later model BC58
I can't find a diagram. The small potentiometer on the control board likely serves as an adjustable component to fine-tune specific parameters. Here are some possibilities: Voltage Regulation: The potentiometer might control the output voltage. By adjusting it, you can set the desired charging voltage for different battery types (e.g., 6V or 12V). Current Limit Adjustment: It could be used to set the maximum charging current. Adjusting the potentiometer allows you to limit the charging current based on the battery's capacity and condition. Sensitivity or Threshold: Some potentiometers act as sensitivity controls. For example, it might adjust the threshold at which the charger switches between charging and maintenance modes. Setting the Potentiometer: Without the specific circuit diagram or detailed information about your charger, I recommend the following general steps: Observe the Potentiometer: Identify the potentiometer on the control board. Note its position and any markings (if present). Consult the User Manual: Check the user manual or operating instructions. It might provide guidance on adjusting the potentiometer. Trial and Error: If no specific instructions are available, start with the potentiometer set to its mid-position. Gradually adjust it while monitoring the charger's behavior (e.g., charging current, voltage). Observe how the charger responds to changes in the potentiometer setting. Fine-tune it based on your specific battery type and desired charging characteristics. Remember that precise adjustments depend on the charger's design and the battery you're charging.
4/20/2024 3:30:25 AM • Motorcycles • Answered on Apr 20, 2024
What is the length of lift cables on a 1993 model 2693 hilo camper and any info on what after market part to use ? thanks
The lift cables on a 1993 model 2693 Hilo camper are 30 feet,2 3/4 inches long and fit the standard height lift of 11 feet 8 inches high to the top of the overhead. The lift uses two cables. According to a Hi- Lo camper travel trailer forum, cable replacement is basically the same on all years and models, with the main difference being the length of the cables from model to model. You can use a cable cut chart to find what cable length you need for your camper, and you'll need to know your year, model name, and box (body) length: Lift cables typically wear out after three to five years, so it's important to replace them as needed and keep them regularly maintained.
4/12/2024 1:26:15 AM • Motorcycles • Answered on Apr 12, 2024
2011 Xingyue Xy260T4 Logo
12 questions posted
Popular Products
Top Xingyue Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Xingyue Expert? Answer questions, earn points and help others
View Most Popular
FLHR Road King Peace Officer Xingyue
  • FLHR Road King Peace Officer Xingyue
Most Popular Question
headlight bulb
  • Motorcycles
