20 Most Recent
Lucent ORiNOCO AP-1000 Questions & Answers
My friend here has an
Check
this tip it can help as a check list.
find user manual and configure a new SSID for your unique WLAN identification a WEP or WPA security protocol with a key you'll replicate on your pc.
let me now if you need detail scoring this solution
Problem in my adapter
From what you said I gather that your AC/DC power supply (power brick) is not working (Suppling voltage to the router). Well this is a case of getting a new power supply. What you can do is find out the voltage output and the current output in amps of the Brick. This information is located in writing on the power brick. Take this information to your local electronics store and get a power brick that has the same voltage, polarity, and current rating as the old power brick.
What are the main components
Definition of:
EGP
(1) (Exterior Gateway Protocol) A broad category of routing protocols that are designed to span different autonomous systems. Contrast with IGP.
(2) (Exterior Gateway Protocol) The
original exterior gateway routing protocol (see above), which has been
widely used in the U.S. Data Defense Network (DDN) and National Science
Foundation Network (NSFNet). EGP is a distance vector protocol that
uses polling to retrieve routing information. EGP has been superseded
by BGP. See BGP and routing protoco
lhttp://www.pcmag.com/encyclopedia_term/0,2542,t=routing+protocol&i=50648,00.aspATP - AppleTalk Transaction Protocol provides a
Transport Layer connection between computers. This protocol guarantees
reliability by directing the transaction process and binding the
request and response. Works at the OSI network model transport layer.
Part of the AppleTalk suite of protocols.
( for Mack ...and aple device )
pseudo-device stfDESCRIPTION The
stf interface supports ``6to4'' IPv6 in IPv4 encapsulation. It can tunnel IPv6 traffic over IPv4,
as specified in RFC3056.
For ordinary nodes in 6to4 site, you do not need
stf interface. The
stf interface is necessary for
site border router (called ``6to4 router'' in the specification).
What is Lucent 7 Cabling?
Lucent 7 cabling *probably* refers to level 7 Lucent cable. It's old!! There are two issues in the question of, "What is Lucent 7 cable?" Here's the history: Lucent was a division spun off by AT&T back in the mid 1990's. Then Lucent actually spun off Avaya and sent their structured cabling business with it (they had named the cabling brand "Systimax" by that time. CommScope bought Avaya back in 2004, so Lucent's Systimax brand of cabling is 2 generations out dated. It's still probably okay, but not worth today's money for new Systimax products made by CommScope.
Now for the 7 issue: there was no talk of category 7 (cat 7) back when Lucent was making cable, but Anixter, a data cable distributor, rates cabling with their own proprietary system called "Levels". Therefore, Level 7 cabling is an Anixter measure and many people have bought from Anixter long enough that they ask for level 7 [brand whatever] cable.
Use it if it's low cost. Otherwise, don't let someone sell Lucent branded-cable as the same as today's cable. There were version upgrades since then. The print on the cable jacket will say 1071C or 2071C or something like that. Today, they are on version E, not C.
Hope it's kind of clear. My guess is the cable is about 10 years old, although some data folks are stuck in their ways and still refer to today's Systimax cable as Lucent cable.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
