20 Most Recent 2011 Rieju MRT 50 Questions & Answers
Rieju mrt 50
Well the horn could be very well grounding out and causing that problem or there is a faulty wire or short running with the horn check all connections for corrosion as well and clean components and re connect everything to see if it stops your problem
3/23/2014 3:54:58 PM • 2011 Rieju MRT... • Answered on Mar 23, 2014
How much is a Rieju MRT 50
Check with a local dealer. if they don't have one, they can't sell you one.If you ask, they may be able to find you one.Good Luck.
11/14/2013 11:24:01 PM • 2011 Rieju MRT... • Answered on Nov 14, 2013
Bike misfiring after flywheel change
The timing gut messed up by a tooth skip on timing chain or some othr mistake. Do uhav a shopbook for that model or some similar guide. Also the computer cud hav issues with plugins or harness wire
6/21/2022 4:52:48 AM • Rieju... • Answered on Jun 21, 2022
Hello, Does anyone have a wiring diagram for a rieju 125 cityline please? My bike won't start i can hear the starter motor ticking over but it won't fire up. The mechanic thinks its a wiring fault but said to diagnose the problem could take a long time and that means money! Any help would be appreciated thanks
Can't help with a wiring diagram. Lots of bikes built in the last couple of decades are fitted with an immobiliser and they are far from trouble-free. The first step when the engine doesn't start is to check the immobiliser is disarmed - if the bike is equipped with one. Often that information is found only in the owner's handbook or at the dealer. Although wiring harnesses aren't very long on bikes there is usually quite a lot of it and manufacturers don't make it any better than it absolutely has to be and there are places where wiring can be stretched or chafed and where it jumps from the frame to the steering there is lots of flexing. I suggest you expose as much of the wiring as you can and inspect it carefully for signs of damage. Check whether the fuse(s) are ok and have power on them will give you a start.
9/20/2020 11:26:44 AM • Rieju... • Answered on Sep 20, 2020
Need Wiring diagram for Rieju Marathon PRO 125sm 2020 i have found a owners manual but there is no wiring diagram there, plz help
https://www.riejuparts.co.uk/ If you perform a search for the rieju marathos pro 125sm and click on IMAGES rather than ALL, you will enounter a number of diagrams of possible interest to you. But you may have to search ebay for such a manual. You do have to be careful to sort through them for this particular Rieju Marathon. Whether or not the parts link listed above might also have wiring diagrams available would require contact with them. You might have to inquire with a dealer for such if indeed them have such access. Here are links of possible help. https://www.riejumotorcycles.co.uk/m/9/marathon-125-sm-ac http://www.riejumoto.co.uk/documents.php?type=5 https://www.oemmotorparts.com/oem2.asp?M=rieju https://www.manualslib.com/manual/958870/Rieju-Marathon-125.html https://bikez.com/motorcycles/rieju_marathon_pro_125_2011.php https://en.wikipedia.org/wiki/Rieju
6/28/2020 11:29:43 PM • Rieju... • Answered on Jun 28, 2020
Hi.I have a Rieju Marathon 125 2011. Bike starts fine but once you give the throttle a blast then nothing happens and no response, just coughs and spluts please help.
check fuel supply--filter air filter -possible vacuum leak--cleaning -rebuild - or replacement of throttle unit
5/3/2020 8:00:39 AM • Rieju... • Answered on May 03, 2020
Rieju RS3 loses engine power
Put some BG or amsoil PI in tank..littl ata time
10/12/2018 3:29:54 PM • Rieju... • Answered on Oct 12, 2018
I've got the Rieju MRT 125 AC Enduro, I've been looking into the derestirction process but I've had trouble actually finding where the restrictions are... Can anyone please help me with this? Lewis
RIEJU MARATHON 125 AC GoPro 2015 - YouTube
? 4:18 www.youtube.com/watch?v=FkedLKGUyXM Jan 28, 2015 - Uploaded by RudeKing Rieju Marathon 125 AC By: Sergi Solanes and Francesc Itchart. ... Eyy Sergi molt guapu el video, aquesta motu 4T com la veus per fer enduro?
9/18/2018 5:22:10 PM • Rieju... • Answered on Sep 18, 2018
How do i check oil on rieju marathon 450
Should be a dipstick up in front of the fuel tank. These have oil in the frame and use a dry sump oiling system. Run it for a few minutes then check. Only holds about 1 litre of oil total so don't overfill. It will only show oil on the dipstick after running a bit as the oil needs to be pumped around the system to be accurate on dipstick reading. --
11/26/2014 8:19:00 PM • Rieju... • Answered on Nov 26, 2014
What causes my fat boy to idle just fine but fall on its face back fire and try to shut down while riding
Some common causes and potential solutions: Air/Vacuum Leak: If your Harley develops a vacuum leak in its air intake system, the air-fuel mixture becomes too rich. This can cause frequent stall outs, especially after the bike warms up. Vacuum leaks often occur due to dried-out or cracked air intake boots, faulty gaskets, or worn-out carburetor seals. When air escapes from the intake system, the fuel fills the empty space in the combustion chamber, altering the air/fuel ratio and negatively impacting combustion. Severe vacuum leaks can lead to excess fuel flowing into the exhaust system, causing backfiring and stalling while riding. Clogged Fuel Tank Filter/Fuel Injectors: A blocked fuel tank filter (due to coagulated fuel, moisture, dirt, or corrosion) impairs fuel flow, resulting in a lean air/fuel ratio. On fuel-injected Harleys, clogged fuel injectors produce similar symptoms. Regular maintenance, including cleaning and inspecting fuel filters, helps prevent these issues. Faulty Cam Chain Tensioner: A malfunctioning cam chain tensioner can affect engine timing and cause stalling. Regular checks and replacements are essential to avoid this problem. Faulty Cam Position Sensor: The cam position sensor plays a crucial role in ignition timing. If it malfunctions, it can lead to stalling and backfiring. Clogged Air Cleaner: A dirty air cleaner restricts airflow, affecting combustion efficiency. Regularly clean or replace the air filter to prevent this issue. Ignition System Failure: Faulty ignition components (such as spark plugs, ignition coils, or wires) can cause misfires, backfires, and stalling. Inspect and maintain these parts regularly. Compromised Battery Terminal Connection: Poor battery connections can disrupt electrical flow, affecting the ignition system. Ensure clean and secure battery terminals. Remember that diagnosing and addressing these issues may require professional assistance. Regular maintenance and timely repairs can keep your Fat Boy running smoothly on the road.
4/21/2024 6:14:37 PM • Motorcycles • Answered 2 days ago
Engine number location on a 2007 c90
Honda C90, or Suzuki C90? all questions need full 'year make model'. Google it plus 'engine number location'. ..
4/21/2024 2:56:52 AM • Motorcycles • Answered 3 days ago
Need circuit diagram for ARLEC 15e 6-24Volt 15Amp Electronic battery charger OR their later model BC58
I can't find a diagram. The small potentiometer on the control board likely serves as an adjustable component to fine-tune specific parameters. Here are some possibilities: Voltage Regulation: The potentiometer might control the output voltage. By adjusting it, you can set the desired charging voltage for different battery types (e.g., 6V or 12V). Current Limit Adjustment: It could be used to set the maximum charging current. Adjusting the potentiometer allows you to limit the charging current based on the battery's capacity and condition. Sensitivity or Threshold: Some potentiometers act as sensitivity controls. For example, it might adjust the threshold at which the charger switches between charging and maintenance modes. Setting the Potentiometer: Without the specific circuit diagram or detailed information about your charger, I recommend the following general steps: Observe the Potentiometer: Identify the potentiometer on the control board. Note its position and any markings (if present). Consult the User Manual: Check the user manual or operating instructions. It might provide guidance on adjusting the potentiometer. Trial and Error: If no specific instructions are available, start with the potentiometer set to its mid-position. Gradually adjust it while monitoring the charger's behavior (e.g., charging current, voltage). Observe how the charger responds to changes in the potentiometer setting. Fine-tune it based on your specific battery type and desired charging characteristics. Remember that precise adjustments depend on the charger's design and the battery you're charging.
4/20/2024 3:30:25 AM • Motorcycles • Answered on Apr 20, 2024
What is the length of lift cables on a 1993 model 2693 hilo camper and any info on what after market part to use ? thanks
The lift cables on a 1993 model 2693 Hilo camper are 30 feet,2 3/4 inches long and fit the standard height lift of 11 feet 8 inches high to the top of the overhead. The lift uses two cables. According to a Hi- Lo camper travel trailer forum, cable replacement is basically the same on all years and models, with the main difference being the length of the cables from model to model. You can use a cable cut chart to find what cable length you need for your camper, and you'll need to know your year, model name, and box (body) length: Lift cables typically wear out after three to five years, so it's important to replace them as needed and keep them regularly maintained.
4/12/2024 1:26:15 AM • Motorcycles • Answered on Apr 12, 2024
Mine is a 410JS 1000cc Santana, Spanish made. Mechanical fuel pump does bring no fuel to the carb. Want to shift to an electric setup. What is the best pump? Do I need an overflow-line?
The bike doesn't exist as written. https://www.google.com/search?q=410JS+1000cc+santana We are better with 'year make model 1000cc'. Better to not try and do better than the bike engineers. A mechanical pump runs when the engine is turning, an electric pump will run as soon as the key is turned and create pressure all the time. It would have to be an in tank electric pump or it will burn out. Electric pumps are cooled an lubricated by the fuel passing through it. If it is a carbureted engine, you are pressurizing the carb bowl. If injected, it may already have a fuel return. Check the mechanical pump for a torn diaphragm, they are easy to change. ..
3/22/2024 10:35:55 PM • Motorcycles • Answered on Mar 22, 2024
2019 Yamaha YZF R15 V3 with 34,000 km driven. The issue is bike at low rpm bike get off frequently and won't start. Sometimes when I accelerate there is lot in delay in acceleration.
Question edited for clarity and add maker. Try cleaning the Throttle Body. This bike works the same as a car. My first thought was that it has a diaphragm carburetor and the membrane was punctured or split. This bike is not sold in North America https://www.google.com/search?q=yamaha+yzf+r15+v3+clean+throttle+body ..
3/13/2024 10:56:26 PM • Motorcycles • Answered on Mar 13, 2024
2011 Rieju MRT 50 Logo
5 questions posted
Top Rieju Experts
john h
Arnie Burke
Arnie Burke
ADMIN Eric
ADMIN Eric
Are you a Rieju Expert? Answer questions, earn points and help others
View Most Popular
Velocity 50 Rieju
  • Velocity 50 Rieju
Most Popular Question
rieju mrt 50
  • Motorcycles
