20 Most Recent
2011 Rieju Marathon Pro 125 Questions & Answers
How do i de-restrict my rieju marathon 125
I've got the Rieju Mrt 125 ac, if recently stripped the whole bike down to try and delete restrict it can anyone guide me through what to do to and where to find the restrictions???
Thanks lewis
Bike misfiring after flywheel change
The timing gut messed up by a tooth skip on timing chain or some othr mistake. Do uhav a shopbook for that model or some similar guide. Also the computer cud hav issues with plugins or harness wire
6/21/2022 4:52:48 AM •
Rieju...
Answered
on Jun 21, 2022
How do i check oil on rieju marathon 450
Should be a dipstick up in front of the fuel
tank. These have oil in the frame and use
a dry sump oiling system. Run it for
a few minutes then check. Only holds about
1 litre of oil total so don't overfill.
It will only show oil on the dipstick after
running a bit as the oil needs to be pumped around
the system to be accurate on dipstick reading.
11/26/2014 8:19:00 PM •
Rieju...
Answered
on Nov 26, 2014
Need circuit diagram for ARLEC 15e 6-24Volt 15Amp Electronic battery charger OR their later model BC58
I can't find a diagram.
The small potentiometer on the control board likely serves as an adjustable component to fine-tune specific parameters. Here are some possibilities:
Voltage Regulation:
The potentiometer might control the output voltage. By adjusting it, you can set the desired charging voltage for different battery types (e.g., 6V or 12V).
Current Limit Adjustment:
It could be used to set the maximum charging current. Adjusting the potentiometer allows you to limit the charging current based on the battery's capacity and condition.
Sensitivity or Threshold:
Some potentiometers act as sensitivity controls. For example, it might adjust the threshold at which the charger switches between charging and maintenance modes.
Setting the Potentiometer:
Without the specific circuit diagram or detailed information about your charger, I recommend the following general steps:
Observe the Potentiometer:
Identify the potentiometer on the control board. Note its position and any markings (if present).
Consult the User Manual:
Check the user manual or operating instructions. It might provide guidance on adjusting the potentiometer.
Trial and Error:
If no specific instructions are available, start with the potentiometer set to its mid-position.
Gradually adjust it while monitoring the charger's behavior (e.g., charging current, voltage).
Observe how the charger responds to changes in the potentiometer setting.
Fine-tune it based on your specific battery type and desired charging characteristics.
Remember that precise adjustments depend on the charger's design and the battery you're charging.
4/18/2024 7:22:52 PM •
Motorcycles
Answered
19 hours ago
What is the length of lift cables on a 1993 model 2693 hilo camper and any info on what after market part to use ? thanks
The lift cables on a 1993 model 2693 Hilo camper are 30 feet,2 3/4 inches long and fit the standard height lift of 11 feet 8 inches high to the top of the overhead. The lift uses two cables. According to a Hi- Lo camper travel trailer forum, cable replacement is basically the same on all years and models, with the main difference being the length of the cables from model to model. You can use a cable cut chart to find what cable length you need for your camper, and you'll need to know your year, model name, and box (body) length: Lift cables typically wear out after three to five years, so it's important to replace them as needed and keep them regularly maintained.
4/12/2024 1:26:15 AM •
Motorcycles
Answered
on Apr 12, 2024
