20 Most Recent
2010 Jonway GTS 500 Questions & Answers
Wet spark plug
Spark plug gets wet because it's running too cold. Loosen plug and retighten only tight enough so it doesn't loosen from vibrations. Just a tad beyond hand tight is enough. This way the spark plugs heat is not dissipated to the cylinder head and run much hotter burning away any excess fuel deposits.
Motor scooter 150cc
take spark plug out and rotate engine till piston reaches the top of its stroke ! use a thin type of rod to feel when this happens and then look at flywheel and you will see the tdc mark line up to marker on casing !
HOW TO REMOVE REAR TIRE TO FIX VALVE STEAM
You don't have to remove the tyre completely ,you just need to break the bead seal on the side of the rim where the valve is situated, why do you want to replace the valve may I ask>
