20 Most Recent 2008 Jialing JH12533 Questions & Answers
What causes my fat boy to idle just fine but fall on its face back fire and try to shut down while riding
Some common causes and potential solutions: Air/Vacuum Leak: If your Harley develops a vacuum leak in its air intake system, the air-fuel mixture becomes too rich. This can cause frequent stall outs, especially after the bike warms up. Vacuum leaks often occur due to dried-out or cracked air intake boots, faulty gaskets, or worn-out carburetor seals. When air escapes from the intake system, the fuel fills the empty space in the combustion chamber, altering the air/fuel ratio and negatively impacting combustion. Severe vacuum leaks can lead to excess fuel flowing into the exhaust system, causing backfiring and stalling while riding. Clogged Fuel Tank Filter/Fuel Injectors: A blocked fuel tank filter (due to coagulated fuel, moisture, dirt, or corrosion) impairs fuel flow, resulting in a lean air/fuel ratio. On fuel-injected Harleys, clogged fuel injectors produce similar symptoms. Regular maintenance, including cleaning and inspecting fuel filters, helps prevent these issues. Faulty Cam Chain Tensioner: A malfunctioning cam chain tensioner can affect engine timing and cause stalling. Regular checks and replacements are essential to avoid this problem. Faulty Cam Position Sensor: The cam position sensor plays a crucial role in ignition timing. If it malfunctions, it can lead to stalling and backfiring. Clogged Air Cleaner: A dirty air cleaner restricts airflow, affecting combustion efficiency. Regularly clean or replace the air filter to prevent this issue. Ignition System Failure: Faulty ignition components (such as spark plugs, ignition coils, or wires) can cause misfires, backfires, and stalling. Inspect and maintain these parts regularly. Compromised Battery Terminal Connection: Poor battery connections can disrupt electrical flow, affecting the ignition system. Ensure clean and secure battery terminals. Remember that diagnosing and addressing these issues may require professional assistance. Regular maintenance and timely repairs can keep your Fat Boy running smoothly on the road.
4/21/2024 6:14:37 PM • Motorcycles • Answered 3 days ago
Engine number location on a 2007 c90
Honda C90, or Suzuki C90? all questions need full 'year make model'. Google it plus 'engine number location'. ..
4/21/2024 2:56:52 AM • Motorcycles • Answered on Apr 21, 2024
Need circuit diagram for ARLEC 15e 6-24Volt 15Amp Electronic battery charger OR their later model BC58
I can't find a diagram. The small potentiometer on the control board likely serves as an adjustable component to fine-tune specific parameters. Here are some possibilities: Voltage Regulation: The potentiometer might control the output voltage. By adjusting it, you can set the desired charging voltage for different battery types (e.g., 6V or 12V). Current Limit Adjustment: It could be used to set the maximum charging current. Adjusting the potentiometer allows you to limit the charging current based on the battery's capacity and condition. Sensitivity or Threshold: Some potentiometers act as sensitivity controls. For example, it might adjust the threshold at which the charger switches between charging and maintenance modes. Setting the Potentiometer: Without the specific circuit diagram or detailed information about your charger, I recommend the following general steps: Observe the Potentiometer: Identify the potentiometer on the control board. Note its position and any markings (if present). Consult the User Manual: Check the user manual or operating instructions. It might provide guidance on adjusting the potentiometer. Trial and Error: If no specific instructions are available, start with the potentiometer set to its mid-position. Gradually adjust it while monitoring the charger's behavior (e.g., charging current, voltage). Observe how the charger responds to changes in the potentiometer setting. Fine-tune it based on your specific battery type and desired charging characteristics. Remember that precise adjustments depend on the charger's design and the battery you're charging.
4/20/2024 3:30:25 AM • Motorcycles • Answered on Apr 20, 2024
What is the length of lift cables on a 1993 model 2693 hilo camper and any info on what after market part to use ? thanks
The lift cables on a 1993 model 2693 Hilo camper are 30 feet,2 3/4 inches long and fit the standard height lift of 11 feet 8 inches high to the top of the overhead. The lift uses two cables. According to a Hi- Lo camper travel trailer forum, cable replacement is basically the same on all years and models, with the main difference being the length of the cables from model to model. You can use a cable cut chart to find what cable length you need for your camper, and you'll need to know your year, model name, and box (body) length: Lift cables typically wear out after three to five years, so it's important to replace them as needed and keep them regularly maintained.
4/12/2024 1:26:15 AM • Motorcycles • Answered on Apr 12, 2024
Mine is a 410JS 1000cc Santana, Spanish made. Mechanical fuel pump does bring no fuel to the carb. Want to shift to an electric setup. What is the best pump? Do I need an overflow-line?
The bike doesn't exist as written. https://www.google.com/search?q=410JS+1000cc+santana We are better with 'year make model 1000cc'. Better to not try and do better than the bike engineers. A mechanical pump runs when the engine is turning, an electric pump will run as soon as the key is turned and create pressure all the time. It would have to be an in tank electric pump or it will burn out. Electric pumps are cooled an lubricated by the fuel passing through it. If it is a carbureted engine, you are pressurizing the carb bowl. If injected, it may already have a fuel return. Check the mechanical pump for a torn diaphragm, they are easy to change. ..
3/22/2024 10:35:55 PM • Motorcycles • Answered on Mar 22, 2024
2019 Yamaha YZF R15 V3 with 34,000 km driven. The issue is bike at low rpm bike get off frequently and won't start. Sometimes when I accelerate there is lot in delay in acceleration.
Question edited for clarity and add maker. Try cleaning the Throttle Body. This bike works the same as a car. My first thought was that it has a diaphragm carburetor and the membrane was punctured or split. This bike is not sold in North America https://www.google.com/search?q=yamaha+yzf+r15+v3+clean+throttle+body ..
3/13/2024 10:56:26 PM • Motorcycles • Answered on Mar 13, 2024
Lexmoto Michigan EFI 125 Euro 5. How to remove the battery cover on a Lexmoto Michigan 125 efi please?
Question edited for clarity. Usually, there are two ways, you either remove a side cover and it comes out sideways, or you remove the seat and it lifts out. https://www.google.com/search?q=lexmoto+michigan+125+efi+battery+cover+removal https://www.google.com/search?q=lexmoto+michigan+125+efi+manual ..
3/9/2024 7:37:19 PM • Motorcycles • Answered on Mar 09, 2024
Hero Honda Karizma R valve clearance please?
Question edited for a lot more clarity. Hero Honda Karizma R 0.10 mm on both inlet and exhaust https://www.facebook.com/WonderMechanicAjayKumarSavita/photos/a.1615112108760566/2952364698368627/?type=3 ..
3/9/2024 1:41:57 AM • Motorcycles • Answered on Mar 09, 2024
How to fix a Pit Bike with no spark please? nosprk pitbike
Question translated for clarity and into written English. :>D Test the coil, test the CDI or Contact Breaker Points if it has them. All questions need 'year make model', or at very least 'make and model' please. Help in the link https://www.google.com/search?q=Pit+Bike+with+no+spark ..
3/6/2024 6:42:06 AM • Motorcycles • Answered on Mar 06, 2024
Xv-bd707 won't start. it stands. "Please wait" in the window.
This is a combo unit. Confirm the disc is playable. The problem may not be in the machine. Check that the power plug is firmly inserted. I have provided links to manuals for the machine. If the troubleshooting therein fails, the remaining option appears to be contacting the manufacturer. Such details should be in the manuals. Pioneer XV-BD707 Blu-Ray Disc Receiver Manual ' HiFi Engine PIONEER XV-BD707 OPERATING INSTRUCTIONS MANUAL Pdf Download ' ManualsLib
3/5/2024 3:11:17 PM • Motorcycles • Answered on Mar 05, 2024
Suzuki Bandit 1200. It was starting with a boost. I left the crappie battery in and now I can't boost to start. The fuses are fine what could it be?
Question edited for clarity. Does it have an aftermarket immobilizer? https://www.google.com/search?q=1200+bandit+immobilizer Is it the fuel injected model? Injection doesn't work if the battery voltage is below 11 volts. ..
3/4/2024 1:11:17 AM • Motorcycles • Answered on Mar 04, 2024
2011 Jurgens Safari Oryx Off-road Caravan. I would like to download owners manual for Jurgens Oryx 2011 please?
Question edited for clarity. Unable to move from Motorcycles as site is broken for moderation. See if this link works better for you. This is a South African Caravan and we are in North America. https://www.google.com/search?q=2011+Jurgens+oryx+manual ..
3/2/2024 6:14:38 PM • Motorcycles • Answered on Mar 02, 2024
Were do the fuel lines go to on a mountop 150cc
This particular unit has a typical GY6-style engine with a fuel line designated from the gas tank to the carburetor distinguished by an in-line cylindrical fuel filter located near the center of the line. Best to locate the carburetor distinguished by the location of the air filter, there should be a hose going from that unit up into the gas tank. Ideally, remove the gas tank entirely and it should reveal the gasoline lines directly to the carburetor. The photo shows the fuel line/filter indicated in red, and the location of the carburetor within the blue indicator. carbfuellocation-undefined-undefined-0.png
2/28/2024 4:42:51 PM • Motorcycles • Answered on Feb 28, 2024
My bike will start and run then it shuts off I replaced plugs and wires but still does it
If a bike runs and then shuts off the reason is lack of fuel. All questions need 'year make model' as first 3 words. It is important. ..
2/28/2024 5:43:00 AM • Motorcycles • Answered on Feb 28, 2024
I have a Jenn Air dishwasher Model JDB1105AWS0 and can't replace the switch
Photo link goes to error 404 and reverts to Panting day in Luci Tusc You posted to the category 'Motorcycles'. Switches often have locking clips on the connectors press with a screwdriver. ..
2/28/2024 1:38:11 AM • Motorcycles • Answered on Feb 28, 2024
Cleaned my carburetors and the Jets and now my bike won't start. I have a spark but it won't start.
All questions need FULL 'year make model', as the first 3 words. Then there are 10,000 categories listed by 'make year model'. So we are working blind. Make sure gasoline is being delivered to the carbs by removing the fuel delivery pipe. Carbs come in different systems. If it has a float bowl on the bottom, tap it with the handle of a screwdriver as it may be stuck. Turn the engine over. If it doesn't start, remove the spark plug and see if it is wet with gas? You need three things for an engine to start Clean gas A spark at the right time Compression You have one thing missing //
2/21/2024 6:59:48 PM • Motorcycles • Answered on Feb 21, 2024
3answers
Locate chassis number of honda wave 125
Should be stamped on the frame under the seat.
2/19/2024 10:17:02 AM • Motorcycles • Answered on Feb 19, 2024
2008 Jialing JH12533 Logo
1 questions posted
Popular Products
Top Jialing Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Jialing Expert? Answer questions, earn points and help others
View Most Popular
CD250D1 Jialing
  • CD250D1 Jialing
Most Popular Question
necesito todo el sistema electrico
  • Motorcycles
