20 Most Recent
2006 Rieju MX 50 Questions & Answers
Bike misfiring after flywheel change
The timing gut messed up by a tooth skip on timing chain or some othr mistake. Do uhav a shopbook for that model or some similar guide. Also the computer cud hav issues with plugins or harness wire
6/21/2022 4:52:48 AM •
Rieju...
Answered
on Jun 21, 2022
How do i check oil on rieju marathon 450
Should be a dipstick up in front of the fuel
tank. These have oil in the frame and use
a dry sump oiling system. Run it for
a few minutes then check. Only holds about
1 litre of oil total so don't overfill.
It will only show oil on the dipstick after
running a bit as the oil needs to be pumped around
the system to be accurate on dipstick reading.
11/26/2014 8:19:00 PM •
Rieju...
Answered
on Nov 26, 2014
What is the length of lift cables on a 1993 model 2693 hilo camper and any info on what after market part to use ? thanks
The lift cables on a 1993 model 2693 Hilo camper are 30 feet,2 3/4 inches long and fit the standard height lift of 11 feet 8 inches high to the top of the overhead. The lift uses two cables. According to a Hi- Lo camper travel trailer forum, cable replacement is basically the same on all years and models, with the main difference being the length of the cables from model to model. You can use a cable cut chart to find what cable length you need for your camper, and you'll need to know your year, model name, and box (body) length: Lift cables typically wear out after three to five years, so it's important to replace them as needed and keep them regularly maintained.
4/12/2024 1:26:15 AM •
Motorcycles
Answered
on Apr 12, 2024
