20 Most Recent
2005 Piaggio X9 Evolution 500 Questions & Answers
Piaggio X9 Evolution 500 back lighting to instrument panel does not work
Hello there, I have a problem with my Piaggio X9 500, 2002 model dashboard. When I turn the key on, the injection, alarm, rear brake, gas reserve, low and high beam bulbs do not check initially , thought they work fine after when I press each button. Could you please give me any suggestion? (the dashboard clocks are NEW!)
Why does it keep making pop po po?
Nice description of your trouble. Guess that you are not too mechanically inclined, (neither me, btw) so if your Piaggio is making "pop po po" take it to a mechanical service.
Bike: Piagio X9 Evolution 500.
Something is wrong with the fuel supply. Since you have flow thru the return pipe it means that the problem is either in the pressure regulator or the injector .
To check them you will need to do 2 tests:
1 - to determine the location of the fault detach the fuel line from the injector, put it in a can and try to start the engine - if the fuel squirts with pressure then the regulator is good and you need to test the injector itself;
2 - connect the fuel line back to the injector, put a multimeter across the contacts and check the voltage when you try to start the engine - if it shows less than 6 volts you have an electrical problem (either a faulty wiring or a defective ECM); if it shows over 6 volts you have a clogged injector - the entire fuel system will have to be cleaned.
My problem is that all
i strongly recommend that you take the bike to someone who knows, brakes are not to be messed with by people who donot know what they are doing ,ITS A SAFETY THING
