20 Most Recent
Parrot CK3300 GPS Receiver Questions & Answers
It will not connect
you will need to delete any old devices from the memory.go to SETTING / PAIRED DEVICES / move onto a paired device and press the middle button , then scroll down to delete and press middle button, then press green to confirm.
The memory is full on
just go to settings -> paired device and then select on the phone you will have to retreive from the kit cause this car kit may accept until 5 phone already paired.
Not connection automatic
You will have to check into the phone cause there is an application which allow to be paired automatically.
If i remember nokia, bluetooth and then you will have a autorize the permanent connection.
It will not connect
First, try to check into settings -> pair with phone and ensure that you do not have already five phone paired with the kit. If yes, just delete one of the phone. If not, you have most of the time a message on the phone saying "pairing fail" or other.
Check to the phone that you do not have the infrared activated. Does the phone find the kit?
You can also trying to retreive the battery of the phone during one minute and put it on again. The try to pair once again.
You can make a crossing test with an other phone to ensure that the kit is working.
Memoery full
memory full not connecting.erased all contacts wont let me connect and ament saying memory full?
Pairing with lg phone
The display should read "Goodbye" when turning the car off. Try switching the inline fuse holders. (Orange and Red Wires)
Garmin 760 bluetooth problem
I also have the 760 & the first gen Boulder (before the front
speaker was added). I had the same issue with the M07 firmware (the
latest you can get over the air), but took it into a Verizon store
& updated it to M09. I am now able to pair the two devices.
Black berry bold does not pair with CK3100
I sent an email to Parrot support and they responded the very next
morning. They suggested I remove some of the paired devices in
the Parrot. I had 5 phones listed in there and deleted them
all. The Bold paired immediately with the Parrot after I did
that!!!!!
