20 Most Recent FIC K8-800T Motherboard Questions & Answers
Problem is in the RAM module, not slot probably. Replace the RAM module and try then
FIC K8-800T... | Answered on May 23, 2011
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
Hope this helps
FIC K8-800T... | Answered on Apr 21, 2011
Most ram has to go in pairs. Buy another stick of the 1GB, and it will run fine.
FIC K8-800T... | Answered on May 01, 2009
Do you have both power connectors from the PSU hooked up?
You need both the large one near the ram, and the smaller square 4-pin one near the printer port
FIC K8-800T... | Answered on Dec 19, 2007
If this is a socket 754 AMD motherboard, then click on this link for drivers or manual http://www.fic.com.tw/support/motherboard/motherboard.aspx?model_id=135
FIC K8-800T... | Answered on Dec 30, 2006
http://www.freeproductmanual.com/lg-ce0168-user-guide/pdf-manual-lg-ce0168-user-guide/
FIC Computers &... | Answered on May 11, 2014
Hello if its drivers you need download here:
http://www.fic.com.tw/download/motherboards.aspx
Select your mainboard PTMQ965
Click on your current windows
And another windows pops up
Here you can select to dowload your file
Good luck
FIC Computers &... | Answered on Oct 31, 2012
FIC FR33E motherboard?
http://www.ebay.com/itm/FIC-FR33E-L-MOTHERBOARD-CPU-LOT-10-/170633274365
Reference: Photo
To the far left side of the motherboard, is actually the Bottom of the motherboard, when installed in your computer case.
The two White long expansion slots you see, are PCI expansion slots.
If one is available, (Open), you can use a PCI USB adapter card.
This is but one example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4143850&CatId=511
Seem cheap? Nope. Good quality also. (You can also check the reviews)
Need guidance in installing?
1) Follow Anti-Static Precautions
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components inside the computer.
Computer on a table, computer unplugged from power, computer case open.
[Note* Always unplug the power to a computer AT the surge protector. NOT at the back of the computer. (Power Supply)
You can cause a power surge ]
2) TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to Touch the metal frame again, upon your return.
3) Finding an open PCI slot look at the back of the computer. In the metal frame you will see slots going horizontally.
These are Expansion Slots.
You may have an add-on adapter card already installed, in one of the PCI slots.
The expansion slot cover for it is removed.
You should see expansion slot covers however, in the remaining expansion slots on the back of the computer metal framework.
Remove the one that corresponds with the PCI slot you wish to use.
Be aware that the PCI slot will not be directly in line, with the expansion slot.
When installing an add-on adapter card, you will see when the card is inserted in the PCI slot, the metal bracket on the add-on card, lines up with an adjacent expansion slot.
This will make more sense to you once you go to install the card.
[PCI USB adapter card is an add-on adapter card ]
Line the card up in the PCI slot. Note that there is a Locating Lug in the PCI slot, and a matching Locating Notch, on the PCI USB adapter card.
Also, at the same time line up the metal bracket of the PCI USB adapter card, with the metal framework of the computer case at the back.
Gently push the PCI USB adapter card down into the PCI slot.
Fasten the card's metal bracket to the computer's metal framework.
Post the computer manufacturer name, and model number, if you need guidance in opening the computer case. Post in a Comment.
For additional questions please post in a Comment.
Regards,
joecoolvette
FIC Computers &... | Answered on Jul 14, 2012
Did you try to install the 1 GB memory module alone & see if it will be fully detected as 1 GB or not?
Also, make sure that the 1 GB module is installed in the first slot (slot 0) and the 256 MB module is installed in the second slot (slot 1). Try doing this and go into BIOS and find "Reset NVRAM" and select "yes".
FIC Computers &... | Answered on Mar 20, 2010
FIC K8-800T Motherboard Logo
Popular Tags
8 questions posted
Top FIC Computers & Internet Experts
Joe Negus
Joe Negus
Marvin
Marvin
madadam1965
madadam1965
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • FIC Computers & Internet
Most Popular Question
memory upgrade issue
  • Computers & Internet
