20 Most Recent
FIC AM 37 Motherboard Questions & Answers
AM 37 motherboard drivers
Hello it should be an Emachine/ Gateway mainboard you have.You can download the drivers for free here:http://support.gateway.com/us/en/emac/product/default.aspx?tab=1&modelId=1431Select the driver by click on the download linkPlease unzip the file before installation.Good luck
10/29/2012 4:00:07 PM •
FIC AM 37...
Answered
on Oct 29, 2012
AM37 & athlon 1.8 gh freezes while setting up XP
More than likely one of the drivers is bad. Hit F8 several
times at startup until the boot screen comes up, select boot into "safe
mode with networking" .Use device manager and see if there are any problems. You can delete the drivers, and download & install new drivers if you find problems.
5/19/2012 9:15:29 PM •
FIC AM 37...
Answered
on May 19, 2012
Beep long
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM and Cmos battery are securely seated
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function
the beeps are post pre operating system searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work
make sure all leads that are attached to your drives dvd\cd have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs all electric current and computer data to travel to and through every working device and have an end to work properly click start right click on my computer so any faulty leads will end up with a computer error
hope this helps
9/5/2011 10:03:03 PM •
FIC AM 37...
Answered
on Sep 05, 2011
Took apart my FIC AM 37 motherboard i (think) i
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
hope this helps
6/16/2011 8:25:28 PM •
FIC AM 37...
Answered
on Jun 16, 2011
HAVE FIC AM 37 MOBO AND THE SW POWER ON IS
It needs to be connected to the F_PNL connector, located near the battery.
It has the following pin assignment:
L+ L- P P x
H+ H- R R N
L ... Power LED
P ... Power button
x ... missing pin
H ... HDD LED
R ... Reset button
N ... not connected
3/17/2010 8:04:40 AM •
FIC AM 37...
Answered
on Mar 17, 2010
Usbs not working
Remove bios battery and erase new bios (usually a pair of pins to short). If USBs now work - don't upgrade bios! If bios settings have no setting for diabling USB, motherboard failrure seems likely. Try a PCI USB card to provide sockets.
9/7/2009 9:32:27 PM •
FIC AM 37...
Answered
on Sep 07, 2009
Power to the mobo
Without having the specs on the motherboard or knowing how old it is, it's difficult to say if it is beyond repair. Although my experience with computers shutting down that quickly while attempting to boot have been a problem related to processor overheating. Processors get very hot within seconds of powering on. If the processor cooling fan or the thermal paste is not working as intended the system will shut down quickly. You may want to check those two possibilities before purchasing a new motherboard.
11/20/2008 12:03:55 AM •
FIC AM 37...
Answered
on Nov 20, 2008
New Processor
No, AM 37 is a socket A motherboard (old), your cpu is new may be socket AM2. look at ebay for AMD socket AM2 motherboard.
7/30/2008 8:45:16 PM •
FIC AM 37...
Answered
on Jul 30, 2008
Motherboard Installation
There are a number of issues that may be causing your problem.
1. Be certain that the power connection is properly installed; there are usually two connections not one that go from the power supply to the motherboard.
2. Be certain that there is no metal on metal contact between the motherboard and the case. Most modern cases include nylon snap-fit spacers that hold the motherboard to the case but also use brass spacers with screws. There should be red paper gaskets included in the parts bag - place these between the motherboard and the screw and be certain that the base ring (a silver metal ring that is not connected to circuits on the underside of the board) is cleanly centered.
3. Finally there are often switch settings and/or tab jumpers that must be set to declare the CPU type, voltage and speed. Be certain that these are set correctly or the board will not power up.
Conclusion
It is difficult to provide any further tips due to the limited information provided and more information may help.
11/14/2007 1:37:45 PM •
FIC AM 37...
Answered
on Nov 14, 2007
