20 Most Recent
FIC FR33E Motherboard Questions & Answers
GTA vice city Hangs !!!????
It does not meet the minimum requirements for the game. you need to have a graphics card in order to play the game without hassle. try playing it on a desktop pc with a graphics card. :)
9/10/2009 8:37:15 PM •
FIC FR33E...
Answered
on Sep 10, 2009
FR33E
make sure both power cables are hooked to the mobo. 24 and the 4 pin.
if still no video check all the cables. is STILL no video what may have happened is that during the case switch you may have given the board a static shock thus shorting out the video chipset on the mobo. you may need to replace it.
8/18/2009 6:49:01 PM •
FIC FR33E...
Answered
on Aug 18, 2009
Graphics probs
check game specs probly needs more like a gig what game is it//oz
7/9/2009 1:19:40 PM •
FIC FR33E...
Answered
on Jul 09, 2009
Fr33e motherboard
you should have a plug like this:
Upper 1&2 - Power/sleep LED
Lower 1&2 - HDD LED
Upper 3&4 - PWR Button
Lower 3&4 - Reset
9/16/2008 12:01:25 AM •
FIC FR33E...
Answered
on Sep 16, 2008
Vicecity is not running in my computer?
IF you are using crack version of vicecity than disable antivirus programme & make 1000mb+ virtual ram ,
this can made from my computer propertie + advanced + settings + advanced,there you can find virtual ram
5/15/2008 4:41:57 AM •
FIC FR33E...
Answered
on May 15, 2008
FIC FR33E long beeb ?
Take out your memory modules and reseat them. One of them may not be in all the way.
AWARD BIOS BEEP CODE ERROR - 1 Long Beep - Memory Problem (Module not seated well)
5/15/2008 1:16:05 AM •
FIC FR33E...
Answered
on May 15, 2008
Installing XP on P III 866 MHz pc
Hi Mri,
Download this software by clicking on this link.
http://www.killdisk.com/downloadfree.htm
Everything you need is on the site. Bottom line, this software will erase your drive & allow you to install Windows XP what every version. You can try installing you're current drive into another working system & you might be able to pull you're personal data off the drive. It's worth a shot. One way or another you're MBR & FAT system are out to lunch. It just happends.(Suprised you haven't received any blue screens)!
If I can be of more service, just post.
Let me know how thing go.
Good Luck!
Mike
5/5/2008 2:55:35 PM •
FIC FR33E...
Answered
on May 05, 2008
MY MONTOR HAS POWER AND IS NOT WORKING.
Hi, dont loose faith.
If you look on your mother board along the edge closest to the front of the case you will see a series of pins, usualy about 10 pins.
Printed on the board will be the names of the plugs that match. The wires from the front of the case have corresponding names.
The power and reset switch will work no matter witch way around you put them.
The HDD led and the pwr led will only work one way so if these lights dont work, just reverce the plugs. If desperate you can bridge two pins together at a time until you get the on/off switch. Note you cant hurt anything unless you use a hammer.
Regards mistyman
9/3/2007 2:42:42 PM •
FIC FR33E...
Answered
on Sep 03, 2007
