20 Most Recent
FIC P4M-800T Motherboard Questions & Answers
RAM upgrate
you can upgrade to a max of 2gb on that board. These are your 1gb options: 1GB PC2700 333MHz DDR Memory, 1GB PC2100 266MHz DDR Memory, and 1GB PC3200 400MHz Non-ECC Unbuffered 184-pin DDR DIMM Memory. Install a set of any of these and your off and running.
My Motherboard ID is PT800-8237-6A6LXF09C-00
In my opinion the NVIDIA chipset cards are the easiest to install. You will need a AGP 4x or 8x card since it is an older motherboard. I have attached a link to the motherboard site and the other is a link to video cards that would work for you.
http://www.fic.com.tw/product/motherboard/intel/P4M-800T.aspx
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007709%20600007850%20600030348&IsNodeId=1&name=NVIDIA&Order=PRICE&Pagesize=100
Thanks for using FixYa
Bios acces
what pc do you have? there are different keyboard shortcuts for various pcs\]\anyway here is a link so you can identify yours good luck
http://www.mydigitallife.info/2008/07/06/comprehensive-list-of-how-key-to-press-to-access-bios-for-various-oem-and-computer-systems/
Upgrade to ram
It's probably high density memory, it's a common problem amongst bargain hunters. There's more about it at the link below:
eBay Guides - Myth Low Density vs High Density memory modulesYou'd be better off getting your memory from somewhere such as ebuyer or microdirect.
Hope that helps. Please remember to rate this solution if you found it useful. Thanks for using FixYa,
erch.
