20 Most Recent
FIC IC-VG61 (dhicecube) Barebone Questions & Answers
CPU Power, Changing to a lover voltage CPU
Hi there
Firstly update the bios, then install the new CPU, go into the bios settings and set them to default, that will auto adjust the computers settings, then you can have a look in the bios again to make sure the voltage is running as preferred.
Good luck and thanks for using Fixya!!!
Case fan won't come on. pulled it and tested okay.What gives?
Yes ...the case fan will no doubt be thermally controlled if it's connected to the motherboard .... and obviously something has gone wrong with the sensor. Have a look round and see if there are any other 2/3 fan connectors on the motherboard you could use. Most times there's the "cpu fn" (we don't want to disturb that one!), "sys fn" and one or more "case fn" connectors, but being a bespoke motherboard in that SFF case you may be out of luck. You've already hooked it to 12v to get it working so it wouldn't be difficult for you to wire it permanently to a spare power connector (you will probably have to cut the cables and rejoin them). However bear in mind that the fan will then run continuously.
New power supply
Hey, I couldn't track down much info on this one either, . . But i did find these 2 places that are linked to Laconic (Enterprises), one looks lke a 'just starting' website, but nonetheless, it has an email, and contact info, the ebay listing shows a variety of 220W Style PSU's you *might*? be able to check into for a compatible one.
http://business.com.tw/com/com.asp?id=hcina151jrbq3c4http://www.laconic.com.tw/new_page_2.htmebayMaybe these will help, if not, feel free to share any more info with me that I can use to help tracking these down for you.
Cheers.
G.
