20 Most Recent
Freecom (22842) CD-RW/DVD-ROM (Combo) Burner Questions & Answers
I can't get the door to slide open,empty or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
also if there is a small hole on the front panel of your cd rw push a straightened paperclip in to the hole until you feel push on button this should open up your cd rw
hope this helps you
My 400gb freecom external hardrive won,t uncompress my files
Have you tried moving the files onto your laptop and uncompressing them there?
Did you have Winrar (or any other copressing software) installed on the laptop before you went back to factory settings? Are the compressed files on the external drive in the .zip or .rar (or another) file format?
Broken usb
several things and solutions you can do.if it's just an external hdd you can rip it to bits and take the drive out and use it as an internal drive, or take it to pieces and get an external hdd caddy for the size of the drive (3.5" or 2.5") they are cheap enough to buy.
10/21/2013 10:02:39 AM •
Freecom...
Answered
on Oct 21, 2013
I have an old Freecom external hard drive
If you checked with alternative cables, and on another computer, then your left with one option only. Removing the HDD from the casing.If the HDD is still working but the case is not. You need to remove it from the case and connect it to a computer directly.If once removed it is still not working you can try to put it in a sealed plastic bag and in a freezer for a day, the quickly try to connect it to a computer.If it is still not working you only other solution is to send it to a specialized company that will open it and read the data directly from the plates. This is done in a sealed environment (think high tech dust free rooms with people coverd in white)Thus it is expensive and usefull only id the data has a real value to you.
10/20/2013 7:38:18 PM •
Freecom...
Answered
on Oct 20, 2013
