20 Most Recent
Hitachi TravelStar DK23FB (08K1427) 40 GB Hard Drive Questions & Answers
Connecting ribbon cable to a Hitachi hard drive
The Red Strip on the cable should face the Power plug on the hard drive. Most times the cable will only go one way to fit.See the link below on which drive to connect where on the ribbon cable.http://computer.howstuffworks.com/ide4.htm
5/27/2012 6:11:45 PM •
Hitachi...
Answered
on May 27, 2012
Hitachi DK23FB-40 not detected
the external hard drive casing may need a driver for some operating systems
and then the unit must be in the on postion
7/19/2009 10:03:28 AM •
Hitachi...
Answered
on Jul 19, 2009
Connect dk23fb-40 ext in front usb
You cannot usually by just the electronics. I would check places like ebay or ask Hitachi about it. The other way would be if you could find someone throwing out one of the drives where something else is bad.
11/16/2007 9:22:25 AM •
Hitachi...
Answered
on Nov 16, 2007
Where can i find drivers for travelsrar 5k500 b-250
Click start control panel administration tools computer management device manager scroll through all of your devices If you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver If you computer came with a motherboard disk the drivers could be on it.
Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 it might take some time being a freeware driver solution Note: it will find all of your outdated drivers This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated. Hope this helps.
1/11/2013 3:13:41 AM •
Hitachi...
Answered
on Jan 11, 2013
Hitachi 50hyt62u H
can I add a removable drive as I have a slot in Back for one, and if so where do I get one
You should be able to buy an external USB drive (or thumb drive) at any electronics store.
You can connect a USB hard disk drive or USB
memory stick to your TV by using the USB inputs of
the TV. This feature allows you to play files stored in
a USB drive. 2.5" and 3.5" inch (hdd with external
power supply) external hard disk drives are supported.
IMPORTANT! You should back up your files before
making any connections to the TV set in order to
avoid any possible data loss. Manufacturer will not
be responsible for any file damage or data loss. It is
possible that certain types of USB devices (e.g. MP3
Players) or USB hard disk drives/memory sticks may
not be compatible with this TV.
Quickly plugging and unplugging USB devices, is a
very hazardous operation. Do not repeatedly quickly
plug and unplug the drive. This may cause physical
damage to the USB player and USB device itself. Do
not pull out USB module while playing a file.
Media Browser Menu
You can play photo, music, and movie files stored
on a USB disk by connecting it to your TV and using
the Media Browser screen. To do this, perform the
following: Connect a USB disk to one of the USB
inputs located on the side of the TV.
You can connect two USB devices to your TV. If both
USB devices include music, picture or video files, USB
selection OSD will be displayed on the screen. The
first USB device connected to the TV will be named
as USB Drive1. Select a device by using up or down arrows
and press OK
11/30/2019 1:10:18 PM •
Hitachi...
Answered
on Nov 30, 2019
