20 Most Recent Hitachi Deskstar 7K250 80GB (hds722580vlat20) 80 GB Hard Drive Questions & Answers
Since it's an IDE hard disk, you'll have to setup disk jumpers, please check the following image:
josema_sv_0.gif If you want more information please see the installation guide at the following link:
http://www.hitachigst.com/tech/techlib.nsf/techdocs/4DD4DCCA11DE5EB186256D6A0061C8A8/$file/Installposter.pdf
Hitachi Deskstar... | Answered on Feb 21, 2011
you can find it from this manuel....
http://www.hitachigst.com/tech/techlib.nsf/techdocs/B272B6575A7B410886256CE90058095B/$file/D7k250_ps1.pdf
Hitachi Deskstar... | Answered on Nov 19, 2010
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password you can change or remove your password from there
good luck
Hitachi Deskstar... | Answered on Sep 04, 2010
No this hard disc is IDE and not SATA.
Hitachi Deskstar... | Answered on Aug 24, 2010
You won't loose your data Why wold you think you would? once data is written to a hard drive it remains there until it is removed be a user, it works on the same principlea a floppy, the magnetic coating on the surface of the anodized disks inside of the HD are written to and retain memory of the data, the only things in a computer that won't keep their data are the RAM chips which need electricity running through them to work.
Hitachi Deskstar... | Answered on Dec 07, 2009
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
2. SATA
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
and
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Hitachi Deskstar... | Answered on Oct 01, 2009
We call them in the industry Death Stars! I have had several just die on me! If the drive does not show in the BIOS then you can't do a low level format! All the ones that have died on me have burnt out components on there circuit boards. Way to small for me to solder! So they were thrown away!
Hitachi Deskstar... | Answered on Mar 19, 2007
Update your ms Drivers and Service pack.
Hitachi Deskstar... | Answered on Jan 27, 2014
Tried googling for the answer but couldn't find it. Try calling an it support company, I'm sure they'll help you out for free. Perhaps you can try https://www.computersinthecity.co.uk/, they have been helpful to me in the past.
Hitachi... | Answered on Dec 07, 2018
Hitachi Deskstar 7K250 80GB (hds722580vlat20) 80 GB Hard Drive Logo
10 questions posted
Top Hitachi Computers & Internet Experts
Alun Cox
Marvin
Marvin
Thomas F. Schneider
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Deskstar Hitachi
  • Deskstar Hitachi
Most Popular Question
set hds722580vlat20 ata ide as slave
  • Computers & Internet
