This is a tough question because it is hard to find this info on the web and a different port is used for DE filters
and sand filters. On sand filters the top port of the filter is the
inlet while on DE filters the bottom port is the inlet. With the valve
not connected to the DE filter and in the FILTER position determine
which port allows water to flow to the bottom outlet of the filter. This
can be easily determined by running water from a hose into the bottom
port and whichever is the pump port will have water coming out of it. A
similar test can be done for the other ports. I hope this helps.
If
this answer does not fix your problem, please comment with additional details
prior to rating the answer. Positive feedback is appreciated once your problem
is solved! Thank you
7 questions posted
337 Questions
104 Questions
92 Questions
