20 Most Recent
Monster Cable Products Monster Beats Solo HD Headphones Questions & Answers
The right earcup in my beats by dr dry solo hd is making a cracking sound when im turning it up and down
that is because you push all the air against the speaker. the air have to get oute somwere. i had the same broblem so i put a little peace of rubber between the ear cushion and the plastick part. so ther is a litte split. if jou has a good peace of rubber or some plastick soft foam en at the top, you just do\'nt see the split. but be carful he can drop in to the speaker. wen you\'ve don dhat you do\'nt heare it enymore if it is good. (my english is not vedry good, iam from holland) i hope it worked for you. :p
Need to repair solo hd
I don't know if it will be any good to you, but take a look at my Tip on headphones. You will find it by clicking my user name.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
