20 Most Recent
Hitachi LG GSA-4120 DVD+-RW/RAM 12x Burner W/ Dual Layer Support (GSA4120) Burner Questions & Answers
Foam ring came out of cd drive
if it was sitting on top of the disk.
it must have been attached to the top-underside of the dvd drive.
this would usually act as padding or a buffer.
the only way, is to open up the drive, and re-fix or glue to the centre of the drive lid/top.
heres your only other option:-
If the front drawer is removable, or detachable. cut a piece of double-sided sticky tape. to the exact shape of the foam ( washer ) we,ll call it. stick to the washer. remove the other side of tape. place the washer on the centre of an old CD. manually eject the cd drawer ( Powered Off )
place the sticky sided washer on the centre of The CD. and place in the drawer. use a spatula or thin Knife, under the CD. to lever the cd, and sticky washer, back to the ceiling/roof of the drive. where it came from.
ensure it,s central. This is just a suggested Thought. And will require some thought before attempting it.
Mike @ Compurepair.
Hello ,
i have this
Hi Iuly,
Download and install CCleaner
(free) from Piriform
Run the cleaner to remove old
un-needed temp files
Select the StartUp tab and look
for any programs that you know you installed but no longer use or
need, and disable them. Caution, do
not disable any system files unless you absolutely know what they
do and that you do not need them.
Run the Registry cleaner, when
asked if you want to backup the registry, select YES,
and save to a file you will remember just in case. I have used this
program hundreds of time on many different system and it has never
caused a problem, but you want to be safe, backup the Registry.
If asked about a particular file
that it wants to clean, select "yes to all"
Reboot
Windows should reinstall the drive when
the computer boots back up.
If this does not resolve your problem,
try the following.
If you take all these step and you
still can not burn a DVD, chances are your DVD burner componet needs
to be replaced. Good Luck.
12/30/2010 10:42:29 AM •
Hitachi LG...
Answered
on Dec 30, 2010
My son inadverdently uninstalled a
the only advice is that click on Start, right click on My Computer, click on Proporties, click on the Hardware tab on the System Properties, click on Device Manager, click on the DVD/CD-ROM drives if its there. if its not there, make sure your dvd drive is connected to the USB or plugged in Internally, click on Scan for hardware changes. thats all i can say. i dont really have that drive. i have the GSA-H21N. i am young and i remembered when i accidently did that to the keyboard. so i figured out how to do stuff like this.
Region Selection
You cannot change the region code again after 5 times of changing even if you move it to a new computer or install a new OS on your computer, I recommend buying a new DVD Drive to access full functionability and no restrictions.
Need drivers for hitachi model gsa-h21n dvd burner
drivers are not needed in order to cd to work, but this problem has aleazrdy been registered.
you shoul click on START, RUN, and type "regedit"
then search in the tree the branch
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
in this, remove the Upperfilters & Lowerfilters values.
reboot, it should work
if really not working after that, download and install the firmware update you can download at
http://drivers.softpedia.com/get/FIRMWARE/LG/LG-GSA-H21N-Firmware-A03.shtml
12/31/2008 10:31:20 PM •
Hitachi LG...
Answered
on Dec 31, 2008
HL-DT-DVD-RW GSA H60L DVDE DRIVE
I just posted a reply to another message that is almost the same. Could be you. It is the foam pad ring from a new CD or DVD spindle that was stuck on a disc that you put in and missed it. It does not go back in the drive. It goes in the trash.
The ring is used hold the discs solidly on new retail spindle. The noise was the drive strugging with an unbalanced disc.
If you caught it right away and nothing hit the laser or lens you are ok. Try reading or burning another disc.
Cheers
12/27/2008 10:24:12 AM •
Hitachi LG...
Answered
on Dec 27, 2008
Hitachi LG GSA-4120B
here's how, you have to oppen that computer, take that cd drive out, dismantle it, and personally clean the lens, duat must have collected on the lens for the long years of not usin it, if you are currently online we'll do the dismantling and cleaning together, contact me e-mail:
[email protected]
mobile phone: +639152192626.
