20 Most Recent Casio LK-100 Keyboard Questions & Answers
you nearest casio dealer may have one in the back of the store,
many buyers don't want/need the manuals so some stores hold on to them for such occassions
Casio LK-100... | Answered on Nov 11, 2018
I would say that something is getting hot in the electronics and causing it to shut down.
Casio should be able to supply you with a list of authorised service agents in your area. So visit there website.
http://www.casio.co.uk/support/servicing-and-repairs
Casio LK-100... | Answered on Jan 04, 2017
What kind/type of your Casio 100?
Casio MT-100,LK-100,CA-100,PT-100,CDP-100 ?
Casio LK-100... | Answered on Sep 03, 2015
If power supply is not original and time of shut off depends on speakers volume I suspect power supply has no enough power. If it is all original then problem may be in power management switching off
Casio LK-100... | Answered on Dec 18, 2014
Read your manual regarding "fingered chords" and similar subjects. It sounds like you are in a single fingered chord mode...
Casio LK-100... | Answered on Jul 21, 2011
You can find the software for Casio LK-70S here: https://support.casio.com/en/support/download.php?cid=008&pid=20 .Look for the driver for the keyboard under the Digital Keyboard/Piano (excluding the PL-40R). Select the appropriate link and then scroll down to the Download button. Another file is the SMF converter. The conversion software is here: http://music.casio.com/e/smf/ . Scroll down to find the download links. This software works with Microsoft Windows 98 SE, Windows XP (32-bit) and Vista (32-bit).
I hope this helps.
Casio Music | Answered on Mar 09, 2019
Try a different pedal. If that does not work try replacing the input jack.
Casio Music | Answered on Feb 11, 2019
Casio CDP has Auto Power Off: 30 minutes after last key operation, Auto Power Off can be disabled.
Please read the manual.
If it turns itself off while playing, I would try to buy a new AC Adapter to test. DC cable of AC adapters are often broken internally after much "bending".
Casio Music | Answered on Jan 14, 2019
You need first of all to remove the cover, access the keybed, remove from keyboard base and then you will be able to remove a key - it is impossible without following this procedure.
Casio Music | Answered on Jan 10, 2019
This doesn't answer your question directly but may help if you decide to get another pedal.
I had a Casio keyboard for a while, and found that the polarity of the sustain pedal was the reverse of that on most other makes. This meant that when I bought another pedal (not Casio), it sustained when not depressed, and did not when depressed. To correct this all I did was to cut the cable near the pedal, reverse the wires, solder them back and cover with nice electrical tape.
By the way if you use SEABOARD or MAINSTAGE then there's a different trick (avoiding cutting wires) on this link:
https://www.google.fr/search?safe=active&source=hp&ei=_94nXKycB5KNrwSa87ewDQ&q=reverse+polarity+piano+sustain&btnK=Google+Search&oq=reverse+polarity+piano+sustain&gs_l=psy-ab.3..33i21j33i160.2290.9757..10489...0.0..0.1422.4626.19j11j7-1......0....1..gws-wiz.....0..0j0i22i30j33i22i29i30.Kw9oNuP5f5o
If this wasn't completely useless then please give this a good mark! Thanks.
Casio Music | Answered on Dec 29, 2018
Casio LK-100 Keyboard Logo
9 questions posted
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
View Most Popular
Casio Music
  • Casio Music
Most Popular Question
could cause keyboard shut off after
  • Music
