20 Most Recent Behringer V Tone GMX212 2X60 Watt Stereo Guitar Combo (Standard) Questions & Answers
How do I edit the midi preset parameters on a behringer gmx212 using a laptop?
by using a midi editor, midi data cannot be changed while traveling through the cable there are 127 different options for midi, and it needs a digital platform to funtion correctly for paramaters.
12/23/2014 11:41:24 AM • Behringer V Tone... • Answered on Dec 23, 2014
Hi, I have a BEHRINGER V-Tone GMX212, I left it
Hi,Did you left the amp on overnight with a guitar hooked up to it?
11/11/2013 1:30:07 PM • Behringer V Tone... • Answered on Nov 11, 2013
2answers
No functions on the front panel..the display does
This is a wild guess, but I have had a different model, a 110, that had a bad electrolytic power filter cap on the effects board that while a meter showed 5 volts for the effects, what was happening is there was dips in the unregulated voltage that fell below what the regulator needed and the voltage to the DSP fell to the point that the DSP was resetting at twice line frequency. This was ONLY visible using an oscilloscope. ALWAYS verify your power supplies with an oscilloscope to look for ripple and noise. With the processor continually reset, the unit appeared to be inoperative.
2/8/2013 10:40:34 PM • Behringer V Tone... • Answered on Feb 08, 2013
I need to know the part number for the main input
To get the official part number for the jack you have to call Behringer at 1-425-672-0816 to get the number AND an incident number. You can order the part from the only Behringer distributor, FullCompass.com. If they don't have it in stock expect to wait months. You can also try this company which may no longer be the main distributor:
http://www.dbmproaudio.com/behrparts.html
1/14/2013 7:30:17 PM • Behringer V Tone... • Answered on Jan 14, 2013
GMX212 I would like to
Remove the side screws ALSO, 2 on each side of the amp
1/2/2013 1:42:29 PM • Behringer V Tone... • Answered on Jan 02, 2013
My handle has broken on my gmx212, how much for a
Call Behringer customer support and they will give you a list of phone numbers of dealers that sell these parts; they will quote you a price.I did this to get the slide switches for the FX board of the GMX212
1/2/2013 1:41:27 PM • Behringer V Tone... • Answered on Jan 02, 2013
3answers
There are 2 bolts on both sides also. Remove them and slide out the metalic pan-like holder where all the electronics is
1/2/2013 1:32:12 PM • Behringer V Tone... • Answered on Jan 02, 2013
0answers
I have a V-ampire combo and it keeps ;loosing the
You need to make sure the decimal point in the display is NOT blinking and then press the IN/OUT key for over two seconds to save the preset before turning the power off. Refer to page 9 of your user manual for this information.
8/1/2011 2:26:40 AM • Behringer V Tone... • Answered on Aug 01, 2011
I have a Behringer PMP2000D Europower 800-Watt 14-Channel Powered Mixer & I'm getting no sound out of channels 1-6 but I'm getting a signal just no sound & fuses are fine
You will need an oscilloscope and a good grounding in electronic servicing to attempt a repair. But, check the signal routing. Refer to the user manual.
1/18/2024 7:34:56 AM • Behringer Music • Answered on Jan 18, 2024
I have a Behringer Xenyx 1204FX and the DSP Display doesn't illuminate (but works by pressing down and turning the knob). Any idea why it's not on? Also the AUX 1 Send doesn't seem to be working
It sounds like you're experiencing a couple of issues with your Behringer Xenyx 1204FX mixer. Let's address each of these problems separately:
  1. DSP Display Not Illuminating: The fact that the DSP display works when you press down and turn the knob suggests that the issue might be related to the display itself or its connection. Here are a few steps you can take to troubleshoot the problem:
    • Check Power Source: Ensure that the mixer is receiving proper power and is turned on. Sometimes display issues can be caused by power-related problems.
    • Connection: Make sure the ribbon cable or connector that connects the display to the circuit board is properly seated. A loose connection could be causing the display to not illuminate.
    • Faulty Display: If none of the above steps work, there might be a problem with the display itself. You may need to contact Behringer support or a professional technician to get the display repaired or replaced.
  2. AUX 1 Send Not Working: If the AUX 1 send is not working as expected, there could be several reasons for this:
    • Routing Settings: Make sure that the AUX 1 send is properly routed to the desired destination. Check the routing options on the mixer to ensure that the signal is being sent to the correct output or destination.
    • Level Controls: Verify that the level controls for AUX 1 are set correctly. Make sure that the AUX 1 knob for the specific channel you're working with is turned up.
    • Effects/Processing: If you're trying to send a signal with effects applied, check if the effects are set up correctly. Sometimes, an incorrect effect or routing setting can affect the AUX send.
    • Cable and Connections: Ensure that the cables connecting the AUX 1 send to external devices (such as monitors or effects units) are functioning properly and securely connected.
    • AUX Master Level: Confirm that the AUX 1 master level (usually located on the main output section of the mixer) is turned up to an appropriate level.
If you've gone through these troubleshooting steps and the issues still persist, it might be a good idea to consult the user manual for your Behringer Xenyx 1204FX mixer for further guidance. If the problems continue, you may need to reach out to Behringer support or consider seeking assistance from a professional audio technician or repair service.
8/6/2023 8:22:16 AM • Behringer Music • Answered on Aug 06, 2023
2answers
Behringer Europower PMP 1680S--The FX channels both Master and Monitor banks do not create any effects but instead only produce a rapid, repetitive clicking/popping noise. HELP!
Hello Geoff, try using an external processor and check that it works well, if so, the problem is that you have the Jack connectors of Effect sending and those of Return of Effects, dirty Apply a couple of drops of oil, type WD40, to a Plug connector and insert and remove them repeatedly in each connector Jack for sending and returning effects I hope you can solve the problem, comment the results Greetings Franco Dosil Hola Geoff, prueba usando un procesador externo y comprueba que funcione bien, si es asi, el problema es que tienes los conectores Jack de envio de Efecto y los de Retorno de Efectos, sucios Aplicale en un conector Plug un par de gotas de aceite, tipo WD40 y entralos y sacalos repetidamente en cada conector Jack de envio y retorno de efectos Espero puedas solucionar el problema, comenta los resultados Saludos Franco Dosil https://media.music-group.com/media/PLM/data/docs/P0A8M/PMP1680S_PMP980S_PMP960M_M_EN.pdf https://c3.zzounds.com/media/PMP1680S_P0A8M_OI_EN_ES_FR-df44b2314272dfc61a7cabe5bb88ecce.pdf
7/29/2023 2:29:41 AM • Behringer Music • Answered on Jul 29, 2023
2answers
Behringer truth 2031a popping and sizziling stoppeed working, what to check first.
Check all the wiring connections on the speaker. Check the plug in points for the cables are not loose in the body of the speaker or the connector plugs themselves are not loose in the actual plug sockets. Next you will need to get inside the speaker body to check the connections and soldered joints. Take a good look at the back of the cable plug sockets and to the back of the actual speaker cone connections. Check each wire at Both ends for damage. No sound at all suggests the issue might be at the 'Input' where the cable plugs into the back of the speaker body.
7/18/2023 3:07:48 PM • Behringer Music • Answered on Jul 18, 2023
Behringer Europower pmp1680s Head/mixer rapidly powers up and down continuously
Sounds like a capacitor is bad.
6/26/2023 1:13:56 AM • Behringer Music • Answered on Jun 26, 2023
Behringer V Tone GMX212 2X60 Watt Stereo Guitar Combo (Standard) Logo
14 questions posted
Top Behringer Music Experts
john h
Are you a Behringer Music Expert? Answer questions, earn points and help others
View Most Popular
Behringer Music
  • Behringer Music
Most Popular Question
gmx212 like
  • Music
