20 Most Recent NetGear FS108 Networking Switch Questions & Answers
2answers
I have forgotten my netgear switch fsm726 v2 username & password
Your username is almost assuredly administrator. You may have to do a reset to get the password.
8/5/2015 4:03:43 PM • NetGear FS108... • Answered on Aug 05, 2015
Need to change NAT settings.
Its simply because this device is dumb (no config) it is just a standard switch no routing aka: NAT.
http://kbserver.netgear.com/pdf/fs105_fs108_install_guide%20.pdf
6/12/2011 1:31:10 AM • NetGear FS108... • Answered on Jun 12, 2011
Blank password does not work
According to this link the default login should be 'administrator' and 'password', or '1234' for older devices.
2/25/2011 4:50:57 PM • NetGear FS108... • Answered on Feb 25, 2011
Problem replacing 4 port hub with 8 port switch for home network.
You can obtain IP details for Preferred DNS server & Alternate DNS server from your internet service provider.
don't use automatic ip addresses.
best regards,
Krishan.
5/8/2009 6:08:24 PM • NetGear FS108... • Answered on May 08, 2009
How To Connect With Mywifiext net Setup Page?
This sounds like an answer to someone's question? You need to click in the MY ANSWER box under the question. It doesn't work adding your ANSWER as a new QUESTION.
3/11/2023 6:13:39 PM • NetGear... • Answered on Mar 11, 2023
How to check netgear r7000 speeds ?
hi please find link for how to check speed https://kb.netgear.com/000038894/How-do-I-check-my-Internet-speed
11/25/2021 1:20:54 PM • NetGear... • Answered on Nov 25, 2021
How to connect PC to netgear WIFI extender
By connecting to your existing WiFi network and enhancing coverage, the NETGEAR range extender enhances your home WiFi network. The steps below will assist you in setting up your extender.We recommend using the Nighthawk app to set up your extension on our latest devices. See the following articles for more information:https://pnews.org/boost-your-speed-with-netgear-nighthawk-r7000/
11/18/2021 3:59:41 PM • NetGear... • Answered on Nov 18, 2021
Belkin f9k1106v1 range extender not connecting
QUICK TIP: When finding a location for your range extender, it is best to place it within the same room as the computer. You can also use https://192.168.206.1 to access the range extender's web-based setup page. Step 1: Place the range extender in an area where the Wi-Fi signal of your router is strong, but near where you want to establish your extended network. Step 2: Plug in the power supply of the range extender and make sure that it is powered ON. Shortly, its light will begin to flash blue and orange. Step 3: Place your computer near the range extender. Also, make sure your computer is not wired to any other network devices. Step 4: Connect your computer to the range extender by opening the list of Wi-Fi networks and selecting Belkin.setup. Confirm that the list shows it's connected. Step 5: Open a web browser, enter https://belkin.range into the Address bar, and follow the on-screen instructions. Don't forget to type "http". Once the setup for your range extender is complete, you may connect the computer to its Wi-Fi.
9/12/2021 1:30:03 PM • NetGear... • Answered on Sep 12, 2021
How can i connect Netgear AC1750 Wifi Mesh Extender manually ?
By Following these steps you can easily setup your Netgear wifi range AC1750 extender
  1. Turn On Your Extender by plugging it into the power outlet, Wait till the extender is turned on and the power led light to stop blinking Once the device is fully booted up,
  2. Now open your web browser, enter mywifiext.net in your web browser if you are Are going to setup your range extender using the window device.
  3. Click on the New Extender Setup , Now Create a new account in case you do not have an account Already.
  4. Accept the term and conditions, Click Continue
  5. Now you will be asked whether you want to Configure your Netgear extender as a wifi extender or as an access point
  6. Click as a Wifi Range extender
  7. Now choose the network you wish to extend and click on the Next button
  8. Enter the password of your current wifi and click next
  9. Be Patience and wait for few seconds.
You had successfully setup your AC1750 Netgear range extender, in case if you are facing an issue with login into your Netgear extender read our extender login guide .
5/6/2021 2:30:13 PM • NetGear... • Answered on May 06, 2021
How can I check netgear extender firmware update version?
By following these simple steps you canupdate the firmware on your netgear Wi-Fi extende.
  • First of all, connect your extender to your router Connect to your extender's Wi-Fi network.
  • Visit at NETGEAR Suppor website
  • Enter your extender's Model Number or Product Name.
  • Click Downloads.
  • Select a firmware version and click Download.
  • Unzip the file if needed.
  • Enter mywifiext.ne. in your web browse.
  • Enter the extender admin user name and password.
  • Click Firmware Update.
  • Click the Browse button, then locate and select the firmware file that ends in .img or .chk.
  • Click the Upload button. The firmware update starts and the extender restarts. The firmware update process takes about two minutes.
If you still face any problem so you can watch this video :-
4/29/2021 7:59:20 AM • NetGear... • Answered on Apr 29, 2021
How do I manually update the firmware on my NETGEAR WiFi Extender?
By following these simple steps you canupdate update the firmware on your netgear Wi-Fi extende.
  • Click Downloads.
4/26/2021 3:31:43 PM • NetGear... • Answered on Apr 26, 2021
2answers
Cannot connect to NETGEAR_NET
https://www.google.com/search?q=NETGEAR_NET&oq=NETGEAR_NET&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
4/8/2021 5:55:57 AM • NetGear... • Answered on Apr 08, 2021
How to fix Netgear Error Code 10 on window 10 ?
  1. Click Start.
  2. Right-click My Computer and select Properties.
  3. Under System Properties, select Hardware tab and select Device Manager.
10/13/2020 6:21:48 PM • NetGear... • Answered on Oct 13, 2020
How to setup Netgear extnder setup?
https://www.youtube.com/watch?v=EkOo_gs5vBw
4/9/2020 2:36:25 PM • NetGear... • Answered on Apr 09, 2020
Netgear extender setup
https://www.google.com/search?sxsrf=ALeKk03PaBlhbIut8HXkWqf7V-HpEgzhdg%3A1585151795759&source=hp&ei=M397XuehLInDlwSL3664Aw&q=Netgear+extender+setup&oq=Netgear+extender+setup&gs_l=psy-ab.3..0l10.2265.2265..3448...2.0..0.245.245.2-1......0....2j1..gws-wiz.....10..35i362i39.kIdrteiVKc0&ved=0ahUKEwinh8zN_rXoAhWJ4YUKHYuvCzcQ4dUDCAU&uact=5#kpvalbx=_1oF7XuuSHITyasH6vLAI26
4/6/2020 1:06:30 PM • NetGear... • Answered on Apr 06, 2020
How to fix Netgear Router Password Recovery ?
To know the complete and simple steps for Netgear Router login you can contact us or visit https://router-logn.net/
3/16/2020 10:43:35 AM • NetGear... • Answered on Mar 16, 2020
How to setup Netgear WiFi Router?
go to negear.com find your router, and read the manual.. RTM what you want to do with no model stated router, is not know by us.. wifi, , Ethernet, and its firewall , or even VPNs are covered
3/16/2020 10:41:05 AM • NetGear... • Answered on Mar 16, 2020
How do I Update my Netgear Router?
Go to the Netgear website and check for the support link, go to that link and look for firmware updates for your model. They install from the computer side of the LAN, you may need to run CAT 5 cable to the inputs to do it.
12/20/2019 12:27:24 PM • NetGear... • Answered on Dec 20, 2019
NetGear FS108 Networking Switch Logo
Popular Tags
6 questions posted
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
FS NetGear
  • FS NetGear
Most Popular Question
forgotten netgear switch fsm726 v2
  • Computers & Internet
