20 Most Recent Iomega 33089 250 GB Hard Drive Questions & Answers
I just completed a back
The backup files are compressed to save space and collect large amounts of data. You must use the method of restoring program/file data to open these files.
2/6/2018 8:01:59 PM • Iomega 33089 250... • Answered on Feb 06, 2018
External hard drive will not mount on my mac
Bet the drive is toast. Get the correct software and do diagnostics on drive to confirm
9/21/2017 9:50:15 PM • Iomega 33089 250... • Answered on Sep 21, 2017
Hi I bought an Iomega model
If it got a network port or network connectivity try using through network.
8/20/2017 7:18:17 PM • Iomega 33089 250... • Answered on Aug 20, 2017
Have a folder that says I need to be admistrator to open I am yet cannot open can you help
You have to be the computers administrator to change any values on any hard drive on your computer click start control panel user accounts on the users tab click the name of the computer administrator you must have full control click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select open Right click the icon of your usb drive (It should be E:/ or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control. if you need more help with this post a reply Hope this helps.
1/10/2013 5:03:49 AM • Iomega 33089 250... • Answered on Jan 10, 2013
My iomega external hard drive is not being
Hi, Thanks for using fixya.
1. With the device connected to the usb port Right click on My Computer choose
manage. On the left side make sure storage is expanded double click disk
management on the left upper side see if Iomega is listed.
2. If it is on the lower part find your Iomega right click on it choose change
drive letter and paths. Click on change, you will see a drop down arrow click
that choose the first available letter, Now click on change. Open My Computer see
if it is now listed. If it is you are done.
3. With the device connected to the usb port reboot your computer when it comes
back,open My Computer see if it is now listed.
Terry
2/13/2011 3:27:23 PM • Iomega 33089 250... • Answered on Feb 13, 2011
My computer wont read my
This is quite a tough one, First does the external hard drive appear when on your computer at all? I would assume disk "c:" that you mention is your main drive or your internal harddrive. If you don't see your external on the computer when you have it plugged in and turned on. Then there is a promblem. 1) Make sure driver is installed, usually when you turn on the external harddrive or plug it in to the computer, the windows sound (found device) usually pops up. 2) Check all connections if all is properly made, and if you have another computer, test it on that computer if you get another different result. If same result is made, and all connection are properly secured. Then you external harddrive enclosure, or the harddrive disk inside it is bad. 3) Listen to your harddrive to see if you hear the drive inside it spins, or if it is making any noise. If spin you could be ok, if it is humming or clicking loudly like it's stuck, then you are kind of done for and could pretty much say goodby to all those files and stuff (with exception) 4) You can take the hard disk inside the external enclosure and hook it up to a computer (if you need help how to, let me know) and see if the computer is able to read it. If not, then definitly your drive is damaged. You can still recover the files, but can't gaurentee a full recovery. In that case, you can take it to bestbuy, office depot, and tell them about the promblem and have them do a data recovery. It is costly, I mean very costly. Anywhere from $250-$750+
Now, if your computer could detect it and give it a drive letter for exmaple D:, but unable to access the files, you can probraly do a error-checking when right click for propertie of the drive.
2/1/2011 2:12:55 AM • Iomega 33089 250... • Answered on Feb 01, 2011
Need manual
USB Desktop/External Hard Drive User's Manual: View Online [HTML] ' Download [295KB zipped HTML]
Quick Start Guide [PDF 564KB]
12/27/2010 7:09:26 AM • Iomega 33089 250... • Answered on Dec 27, 2010
Please send me manual of 250gb iomega portable
12/24/2010 10:05:24 AM • Iomega 33089 250... • Answered on Dec 24, 2010
I have an iomega 250
i have an iomega 320 gig external hd. went to plug it in one day and my pc said it couldn\'t read any of the files. i can still see thumbnails and view photos but can\'t transfer any data at all. please help as i stupidly put all my files on this drive. about 10 years worth of work.
12/9/2010 12:37:20 PM • Iomega 33089 250... • Answered on Dec 09, 2010
My iomega 1tb is "read
Any Hard drives before getting to used with MAC OsX has to be formatted according to the MAC file system...
I think that is the problem you are facing...
Make sure your hard disk is not formatted for any windows OS and try to reformat for MAC OsX...
It should work...
12/9/2010 4:14:52 AM • Iomega 33089 250... • Answered on Dec 09, 2010
.. the blue light is blinking, when i plug in the
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s using a multimeter or if you can see the drive control panel administrive tools,computer management disk management right click on your drive select properties click tools you should see two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart hope this helps
12/5/2010 6:07:20 AM • Iomega 33089 250... • Answered on Dec 05, 2010
External HD won't mount
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
9/29/2010 9:22:09 AM • Iomega 33089 250... • Answered on Sep 29, 2010
I have formatted my hard drive for PC and loaded
u need to format your hdd for using with mac.... if u do so u ll lose the data already stored in the hdd...better use a different hdd...
9/27/2010 1:40:43 AM • Iomega 33089 250... • Answered on Sep 27, 2010
External hard drive is corrupted
try to format it
6/14/2010 5:29:51 AM • Iomega 33089 250... • Answered on Jun 14, 2010
Iomega hard drives seem to give my MAc finder brain freeze
It's possible that ONE (or maybe BOTH) of the drives are defective. Disconnect one of them, and continue to use your computer. If the "freeze" never appears, then the non-connected drive is defective, and, since it is a "new" drive, you can get it replaced, for free, under warranty. If the "freeze" appears, then the currently-connected drive is defective, and needs to be replaced.
4/2/2010 2:02:40 PM • Iomega 33089 250... • Answered on Apr 02, 2010
Hi I purchase an Iomega External Hard Drive 500 gb
ur harddrive couldnot be formatted probably due to the infection of virus.
try this use window xp and connect ur hard drive open task manager by Pressing CTRL + ALT + DELETE
click on the process tab a list of all the processes going on will come,there u will find a process named explorer.exe
right click on it and select end process tree click yes
after that click on applications tab and click new task
enter explorer.exe on textbox and click ok.
now dont open ur external hardrive ,open mycomputer then quickly format ur hard drive.
3/31/2010 4:31:39 PM • Iomega 33089 250... • Answered on Mar 31, 2010
My Iomega Model LDHD320-U is not being recognized
This generally means either there is a corrupted driver on your computer, a fault in the circuit board in the iOmega enclosure or a failure in the drive itself.
To test the driver, try the drive on a different computer first if it works there let me know and I can guide you through replacing the driver.
If it fails to work on another computer then try moving your hard drive into a new enclosure, the techs at your local PC shop should be able to do it for you.
If this works, you're in good shape, if not you may need to invest in some data recovery software or refer the drive to a professional. Either way let me know which method you prefer and I'll be happy to help.
Hope this helps FixYa,
Crankstart
3/24/2010 1:42:43 AM • Iomega 33089 250... • Answered on Mar 24, 2010
Solution CD for Iomega Network Hard drive 250Gb
You get the drivers at Iomega.com and look under support to get your drivers.
REMEMBER you need to install those drivers to ONE pc and then have all your computers networked to it thru your network neighborhood. Any other questions, please write back to me, ok?
3/16/2010 12:42:18 PM • Iomega 33089 250... • Answered on Mar 16, 2010
My computer wont read my external hard drive
some external drive needs driver
3/12/2010 2:43:13 AM • Iomega 33089 250... • Answered on Mar 12, 2010
IMac failing to recognize Iomega UltraMax Hard Drive
I have the same problem too, this iomega is terrible, I have it only less than two months and it is not working already. Evan it has one year warranty I will not suggest anyone to buy it in the future.
2/28/2010 3:03:14 AM • Iomega 33089 250... • Answered on Feb 28, 2010
Iomega 33089 250 GB Hard Drive Logo
Popular Tags
59 questions posted
Top Iomega Computers & Internet Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Jerry Naidoo
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Iomega Computers & Internet
Most Popular Question
formatted hard drive pc loaded
  • Computers & Internet
