20 Most Recent
Ibanez GSRM20 GSR Series Electric Bass Questions & Answers
I have a grounding problem
You need to ground the recorder. Use a WYE connector to get access to the barrel of the guitar cable and find a good ground on a three wire cord wall receptacle. You don't say what model recorder you have which would have been helpful to us. We are surrounded by electric and magnetic fields and typically you can pick up 10 volts AC (with no real current) just as an antenna from the building wiring. Many music devices that run on "wall wart" power adapters have this problem. Also keep guitar away from wall warts as they emit strong magnetic fields for those that use conventional transformers.
What type of input Jack do I need for a ibanez guitar amp tbx30r?
i believe you need a 1/4" unbalance plug for the amps input. Basically a guitar cord. If I am understanding the question. ? or if you want to know the actual "input jack",Maybe it is lacking or missing? than that would be a "1/4" unbalanced input jack". good luck, I hope this helps.
8/26/2019 10:28:56 AM •
Ibanez Music
Answered
on Aug 26, 2019
CAN YOU TELL ME ABOUT THIS IBANEZ GUITAR SN 890453
Ibanez serial numbers were a patchwork over the years, very confusing, but most started with a letter. Those that did not were a 7-9 digit number.
I can't find anything that matches your number sorry. Hopefully someone else has better listings.
9/16/2017 3:13:20 AM •
Ibanez Music
Answered
on Sep 16, 2017
